Replacing stock jumpers
Midnite Mick
I just read in another post about somebody replacing the stock jumpers of the lsi line with 12 gauge speaker wire. How many people do this and what improvements have you heard? If you have tried this and didn't like it tell me why. I have lsi15's and have never even given it any thought.
Oh and if you do replace them are you using spades?
Mike
Mike
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Consonance cd120T
Usher CP 6311
Post edited by Midnite Mick on
The idea is that speaker wire has gotta be a better conductor than those cheap brass jumpers. Just cut four pieces of 3" bare speaker wire and try it for yourself. Good to do even if it's for peace of mind. I've done it a couple of times, but can't say that I actually heard an improvement.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I think it took me too long to go from the brass ones to the homemade jobs to do a quick a/b between the two. It didn't make enough of a difference to stand out much, but it surely didn't make things sound any worse. I just used 6" long pieces of the same 12 awg wire I use to connect my speakers to my amp.
It's a cheap experiment that's worth trying out. Since I use bananas for my normal speaker connection I just used bare wire for the jumpers and then the nanners into the top posts.
