what's the next step?
phipiper10
phipiper10 Posts: 961
edited March 2006 in 2 Channel Audio
Ok, in terms of two channel listening I'm looking to make the next move. Believe my system details are below.
Where do you guys think my money would be best spent?
New CD Player or Preamp
I'm looking at used $200-$300 or so for starters.
CD player (1996)
DVD(CD) Player (2003)
The DVD player in my in home comparisons actaully seems to have a bit more detail and more definition at the lower end IMO. I'm hoping to bring it in to my local HIFI shop tomorrow to do some A/Bing between my current and their $300-$400 Adcom just to get an idea of the difference.
On a slightly different note I'm getting a Hsu sub. After hearing back from Dr. Hsu he says the STF-2 will do the job for me and my room.
Anyone else with the RT800I play 2.1 channel. I keep wondering with the RT800is not being know for their bass what adding a sub might do?
Anyone tried with and with out the sub with these mains?
Thanks All........... still learning.
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    Get a new CD player.
    Great choice on the sub.
    "God grooves with tubes."
  • organ
    organ Posts: 4,969
    edited March 2006
    Save up a little more and get a cdp in the $500 price range. Or you can find those used for around $300. I think this is the price range where cdp's start to sound real good.
    Get the pre after. Start at the source.
    I used to own a pair of 800i's. They had very good bass. Of course, you will get much better performance when your HSU arrives.
    Also, I find that it's pretty hard to get the 800i's to blend in with the sub without crossing them at 80Hz. You should play around with that when you get your sub.
    F1nut Posts: 51,776
    edited March 2006
    FWIW, I concur.
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    edited March 2006
    I think is better a cd changer over cd player. My recommendation, with low bucks, is a Yamaha CDC 685 ... great sound quality, optical output and very reliable. Try it !!!!!
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited March 2006
    I think single dedicated players are better than multiple changers as far as audio goes. Maybe not by much but that has been my experience.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • ND13
    ND13 Posts: 7,601
    edited March 2006
    What about trying a decent used DAC??? Definitely couldn't hurt matters.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • Tour2ma
    Tour2ma Posts: 10,177
    edited March 2006
    I can't see you making great strides on a $300 budget.
    I'd save up for a 2-ch break out maneuver.
    More later,
    Tour...
    Vox Copuli
  • ND13
    ND13 Posts: 7,601
    edited March 2006
    For just a little more, he can get one of the Sheng Ya/Kavent tube cdps like Halo and I use. Rich(SCompRacer) has stated, after a side by side comparo, that it's on par with his Ah! with upconverter mod. That's saying something!!! Were talking about a $600 savings over the Ah! Tjoeb player after the upconverter being added. The Sheng Ya is built like a tank. All metal chassis, Burr-Brown Dacs and opamps(if utilizing the digital output), Solen Caps, and it weighs in at just ounces under 20 lbs. It's also HDCD capable and has it's own volume control for those like me without a remote for the preamp. I got mine used for $387 shipped. It was only used for a few hours, said the previous owner. I had no reason to not believe him once I got it. The seal on the back had never been cracked and it looked just like new. Even had that new smell to it.
    One thing to remember, though, is the Sheng Yas are 220volt and need to be converted(fortunately mine was already done by the dealer he ordered it from) to 120 or you need a stepdown. I believe the Kavent is made for the US market and is already 120 volt. But, imo, you'll be VERY hard pressed to top it for anywhere close to it's price.
    Good Luck!!
  • *Seby*-Polk-
    edited March 2006
    What is your experience ??? i mean..you can listen a same CD first in single player and then in changer ??? (obviously, same brands...)
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2006
    There is less to go wrong in a single-disc CD player, and the transport is obviosly going to be sturdier, meaning, I would assume, less vibrations. Also, the higher you go up the CDP food chain, the rarer CD changers become.
    You can find a really nice CDP for around $300. I did. :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • halo
    halo Posts: 5,616
    edited March 2006
    Good Luck!!
    I have both the Kavent CD-731 & the Sheng Ya CD-S10. As with anything else in the used market patience is a virtue. I've seen a total of six between Audiogon and eBay since October - Noel snagged the first one and posted a review. I looked, waited, made offers, got shafted twice and then I got lucky and bagged two in under a month. These are excellent - especially after a little tube rolling. I found synergy with a Raytheon 12AU7 and an Ei elite gold pin 6DJ8.
    A used Rotel 1070 or 1072 is a very nice player that usually goes for $500 used. As Noel stated a Kavent or Sheng Ya can be had for much le$$ and will easily leave the Rotels in the dust - I had a RCD-1070 and IMHO there is no comparison. Tube gear > SS gear.
    Organ & F1nut are 100% correct - it all starts at the source. With a tube CDP you are killing two birds with one stone. In some cases the tube CDP can act as the pre if it has a remote volume control - like the Kavent, Sheng Ya, and Ah!
