would this work??????
dangerranger
JBL Power BPX500.1 specs are Amplifier Type: Mono
RMS Power: 718W x 1 @ 4 Ohms
THD at 4-Ohm RMS Power: 0.5 %
RMS Power: 674W x 1 @ 1 Ohm
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: None
Frequency Response: 25.4-340 Hz
Signal to Noise Ratio: 66.4 dB
whats would the rms be at 2 ohms???? reson i ask is couse my buddy works at ups and can get real good deals on jbl and infinity.so i could get this amp cheap.im hookin 2 12 inch momos up single voice coil whitch i just got yesterday..i was gonna get that profile but i forgot he can get real good deals on jbl and infinity and iv herd good things about jbl thats why i changed my mind.well anyway i was wonderin if this amp would even work with the 2 subs or what the rms at 2 ohm would be..later
Preamp Outputs: Yes
Bass Boost: None
Post edited by dangerranger on
or how about this amp. Infinity Reference 611a
RMS Power: 456W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: <1 %
RMS Power: 657W x 1 @ 2 ohms
Preamp Outputs: Yes
Bass Boost: 0 - 12 dB
Frequency Response: 17-302 Hz
Signal to Noise Ratio: 70 dB i can get this amp for 160 bucks and its on crutchfield for 350 i think and iv read real good reviews on this amp.whitch one out or the profile,jbl or the infinity do you guys think would be the best bet -
The Infinity would be the better match. The JBL is too powerful.polkaudio sound quality competitor since 2005
allright thx im havin my buddy order the amp tommaro.thx for all the help guys
