Need budget cable recommendation
billbillw
billbillw Posts: 7,549
edited March 2006 in 2 Channel Audio
Ok, I'm picking up a TT that has RCA connectors instead of permanantly mounted cables (HK T55C). No cables included, so I will probably need a 1m pair of interconnects.
I've read at various places that you want to keep capacitance as low as possible on cables used for phono signal. Should I even be worried about this for a 1m length? If so, any off the shelf, affordable cables that somebody could recommend?
Post edited by billbillw on
