Phono Input Uses
zingo
zingo Posts: 11,258
edited March 2006 in Electronics
What have you used the phono input on your pre-amp or receiver for besides a turn table?
Post edited by zingo on
    mhardy6647 Posts: 35,230
    edited March 2006
    Now, either I am missing something, or this is an odd question.
    Well, a magnetic phono input (which I assume is what you refer to) has enough gain to take a tape head output as an input, but not the right EQ.
    I have seen "reverse RIAA network/attenuator" gizmos for sale that would let one use a mag phono input as an additional line-level (AUX) input, but that is a truly bizarre solution to the 'not enough inputs' problem!
  • HiPerf360
    HiPerf360 Posts: 436
    edited March 2006
    Nothing, they are totaly different.
  • DiscoMike
    DiscoMike Posts: 114
    edited March 2006
    If you have a moving coil cartridge, you should be able to stick it into any input other than the phono input as it does not need a preamp stage (from what I remember reading).
    I've never used or seen a phono input be used for anything other than a turntable being hooked into it.
    edited March 2006
    Negatory, good buddy. Virtually all moving coils are very low output and low impedance, and need either an additional gain stage (head amp or pre-pre amp) or a step-up transformer. There are some high-output MC cartridges (e.g., Sumiko Blue Point), but they're at MM levels, not line levels, and still need EQ.
    Having said that, there are two (and I think three) flavors of phono cartridges that'll work with a line-level, un-equalized input: ceramic (piezoelectric), crystal, and "strain-gauge" (maybe also called "solid state"). The first two are generally not the provice of hi-fi (or record longevity), and I don't think there are any current suppliers of the latter.
