How to get surround output on Xrt12?
bort
bort Posts: 4
edited March 2006 in Electronics
Three of XM Radio's new channels are available in 5.1 surround (76 Fine Tuning, 113 Classical Pops, and 200 XM Live), with more to come. Is there a way I can get my Polk XRt12 to decode the surround information?
The XRt12's product description claims it should be able to do this:
Hooking up is a snap. It features both Optical and Coaxial digital outputs for easy connection to surround receivers and processors. If XM goes multi-channel-you'll be ready!
Also, is there a newer firmware that solves problem #1 mentioned here? My receiver does this, too.
Thanks,
bort.
Post edited by bort on
  • Zen Dragon
    Zen Dragon Posts: 501
    edited March 2006
    Not completely familiar with the Polk unit, however if the channels are broadcasting in the 5.1 format there should be some sort of indication on the unit it recognises the 5.1 signal. You will have to have either the coax digital output or the optical digital output hooked to your receiver.
    I'm assuming the Polk unit decodes the 5.1 signal. There is probably a funtion on your receiver to let it know it will be receiving an externally decoded signal. Make sure that is enabled.
    If you are still having trouble you may wish to contact Polk.
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2006
    polkcs@polkaudio.com.... 800-377-7655
  • fireshoes
    fireshoes Posts: 3,167
    edited March 2006
    I haven't got to try it out yet, but the new lower line Yamaha receivers say they have Neural Surround, which is supposed to be the 5.1 for XM. Maybe the receiver has to have the decoder? I'm unsure.
  • bknauss
    bknauss Posts: 1,441
    edited March 2006
    Can't get the 5.1 off the XRt12 unless Nueral or someone else comes out with a standalone unit.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2006
    Huh, you mean the XRt12 will not or can't send 5.1 down it's optical output?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • bknauss
    edited March 2006
    Uh... don't know how to answer that question. Unless the Yammy allows an external signal other than XM to go to the Nueral decoding hardware/software (which I would doubt they allow), there is nothing on the market that I know of that could use the XRt to decode the signal from it.
    There was a magic black box at AES 2004 that used the XRt12 and decoded the XM 5.1 signal, but I don't believe that's on the market. Looks like everything that is coming out with the ability to decode is an AVR.
    Brian Knauss
  • disneyjoe7
    edited March 2006
    OK I understand.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
