excursion of subwoofer hits the grill
last night while watching star wars II, i noticed at the beginning of the movie the sub was putting out certain frequencies that was causing the speaker to hit the grill and make a loud vibrating sound. If I take the grill off, then the noise goes away. Anyway, I was just wondering if anyone has heard of this happening before or if this sub is just being pushed too hard. The volume levels werent too loud, so Im not sure why this is happening.
Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
Post edited by sickicw on
Oh yea it is a Infinity CSW-10PolkThug wrote:Which sub do you have?Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
Take a dremel tool to the backside of the grill and free up some space.
Has the subs been pushed hard and loosened or damaged the surround? If it is in great shape, I would just go with PolkThug's adivce and free-up that excursion.
PolkThug wrote:Take a dremel tool to the backside of the grill and free up some space.
Can you explain how to do this. Do you mean to add some type of spacer between the grill and the speaker?Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
a spacer would most likely a better idea just cut a wooden ring thats bigger than the surround on the inside, but a hair smaller than the frame onthe outside and reattach your grill
