rear wall 20ft away
sunjai
sunjai Posts: 13
edited March 2006 in Speakers
Hi guys, i'm planning to move into 7.1 setup.....
but my rear wall is 20ft away from my listening position......
should I use wall mount for rear speakers of stands???
if stands how far away from my listening position......
and how high should the stands be??????
my setup is CSi5, RTi38 and FXi5......what should I get for rear??? or should I move the RTi38 to the back....
Post edited by sunjai on
  • aaharvel
    aaharvel Posts: 4,489
    edited March 2006
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • sunjai
    sunjai Posts: 13
    edited March 2006
  • Skynut
    Skynut Posts: 2,967
    edited March 2006
    I say put them on stands with the tweeter at or just above the level of your ear when you are seated.
    With stands you can move them around to find the perfect place for them.
    Experiment with them and see what you like.
    20' is not to far if you wanted to put them on the wall.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Skynut
    Skynut Posts: 2,967
    edited March 2006
    Also I would probably start out with the fx's on the side and the 38's in the rear near the rear wall.
    The object of the rear and surrounds is to give you sound from behind but not really a location for the sound.
    In other words you want to hear sound but not be able to tell where it came from unless a specific scene puts sound in that location of the room.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
