DAC hookup/problem
opus
Hi All,
so I got my DAC from Madmax and hooked it up as follows:
from digital out on cdp to digital in on DAC.(coax)
from analog out on DAC to cd inputs on preamp.
When I play a disc I get some sound and some static. I swapped out the analog Ic's with the same result. I ran the coax straight to the preamp and the sound was good. So any ideas on the problem?
Any help is good:)
kevin
Any help is good:)
kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Hitachi 50VG825 LCD
LsiC, Fxi30's
Post edited by opus on
Isn't there a switch on the front of the DAC that selects either a COAx or different digital input? Make sure that's set for COAX.
Hmm...other than that, I don't really have any ideas. Sorry for the elementary suggestion...that's as far as my knowledge extends!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Thanks 'bliss
there is a selector switch for digital 1 or 2 and a phase switch 0,180. On the back is another switch called I^2.. No other settings or switches available. It sounds like maybe some sort of electrical interference.The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)-flea market
LsiC, Fxi30's
Signal Cable and Kimber Kable -
When you say you get some 'sound and some static', do you mean you just get noise and static? Or do you actually get music and static? Is the music at a lower volume level than usual?
The only culprits I could think of would be terminals and cables. Assuming those are good, I guess the problem would have to be with the CDP's digital output, the DAC's digital input or output, or the receiver's analog output. Since you were previously using the RCA inputs on the receiver, those should be good.
I don't know.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
audiobliss wrote:When you say you get some 'sound and some static', do you mean you just get noise and static? Or do you actually get music and static? Is the music at a lower volume level than usual?
Music and static:mad:The Flea rig
Hitachi 50VG825 LCD
LsiC, Fxi30's
what type or brand of DAC is it? Is it a tube DAC? Ask MadMax, i'm sure he'll know what the problem is.PolkFest 2012, who's going>?
It's the Audio Alchemy DAC "Digital Decoding Engine V1.0" madmax sold in the FM hereGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
I'm sure Madmax will stumble across here sooner or later.The Flea rig
Hitachi 50VG825 LCD
LsiC, Fxi30's
Ok, so here is what I think.
It seems that male and female power connectors on the back are not connecting properly. Sometimes the plug works its way out a little. When properly inserted and held in the unit sounds fine. Looks like the female part has some sort of tensioner or "springy" clip to hold in the male that doesn't always hold good enough.
The Flea rig
Hitachi 50VG825 LCD
LsiC, Fxi30's
Just for reference, here's a pic of the back of the unit, with the DC input on the far right.
I'm not sure what you can do about that, but at least it's nothing wrong with the actual audio-related parts of the equipment.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
With AA DAC's and DTI's (jitter units) you MUST make the power supply connection to the unit first and then plug the PS into the wall outlet. In the other order you endanger frying the DAC/ DTI.
Not sure how you started off, but your loose connection is likely making and breaking the electrical supply at the wrong end.
Unplug the PS from the wall until you figure how to make the connection solid at the DAC's end.
Not sure off-hand how to tell you to do this, but as soon as I can (Thursday will be the earliest), I will look at my units and see if I can sugest something.More later,
Tour...
Vox Copuli
Tour2ma wrote:With AA DAC's and DTI's (jitter units) you MUST make the power supply connection to the unit first and then plug the PS into the wall outlet. In the other order you endanger frying the DAC/ DTI.
Thank you:)The Flea rig
Hitachi 50VG825 LCD
LsiC, Fxi30's
You're welcome...
Which AA DAC is it? V1.0, DITB, 2.0, etc...More later,
Tour...
Vox Copuli
Tour2ma wrote:Which AA DAC is it? V1.0, DITB, 2.0, etc...
*sigh* Here's one of my earlier posts. :rolleyes:audiobliss wrote:It's the Audio Alchemy DAC "Digital Decoding Engine V1.0" madmax sold in the FM hereGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Gotta get my money back from Evelyn Woods...
Got it...More later,
Tour...
Vox Copuli
Hi Opus,
Yes, the power supply should be plugged into the DAC before plugging it into the wall otherwise you could get a small spark. It can make a short as you slide it in the jack due to the design. The plug pulling out of the unit seems odd. I've used it off and on for various CD players and have never had that happen. Is the weight of the power supply pulling on it? It should not be hanging. Let me know. Worst case I offer a full warranty.
madmax
Sending PM.Vinyl, the final frontier...
madmax wrote:Worst case I offer a full warranty.
madmax
Sending PM.
Nope. that is just what Audiobliss wants:p.
It is my opinion (uneducated as it may be) that the plug is not making a proper connection with the receptacle. I still get static and music when I hook it up DAC first and wall outlet second. There seems to be an inordinate amount of play in the connections. What do you think about that?The Flea rig
Hitachi 50VG825 LCD
LsiC, Fxi30's
I think its a bad connection. Your saying the connection to the DAC is loose? Can you very carefully crimp the connector on the coax cable a bit? Sometimes I can just squeeze them with my fingers hard enough to close them enough, sometimes I use a small plier with a cloth around the connector to help minimize any damage.
Are we talking a big bucks connector?
RT1 -
opus wrote:Nope. that is just what Audiobliss wants:p.
Waaaaaaaaaaaaa...
Answered your PM. There shouldn't be much play.
Forgot all about this.... Still having issues?More later,
Tour...
Vox Copuli
I guess not, dad-nabit. Guess that means he's keeping it!
:cool:
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Tour2ma wrote:Forgot all about this.... Still having issues?
Thanks Tour for remembering.
Nope. No more issues. I got the plug to seat properly and have left it alone since then. Sounds wonderful and even better with new flea market PBJ's. Max offered to fix it but I don't want to be without it for the week:)
Now if I can find a jitter reducer I will be set...(never ends does it:o )
kevinThe Flea rig
Hitachi 50VG825 LCD
LsiC, Fxi30's
LOL.... well, at least I remembered that I forgot...
Cool.... AA has several different models, and I own them. I loaned one (the v1.0, I think) to Russman and he noticed no improvement. I sometimes do.
As you are a member in good standing, if you want to try one, PM me your addy.More later,
Tour...
Vox Copuli
