cable management.....help!!
pmckeealaska
Now that I have completed my 5.1 setup, I have a problem that is part aesthetic and part practical in nature. I have cables going everywhere. Not only the speaker cables, but subwoofer cables, interconnects, and cables for the HT and SACD/DVD-A playback. It is a real mess behind the TV.
How do folks with extensive wiring issues, keep things neat and tidy? Would plastic ties work for groups of cables, or is this a bad idea? Any suggestions would be appreciated.
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
LSiC Center Channel
LSiFX Surrounds
NAD T763 Reciever
Post edited by pmckeealaska on
Pull-ties, velcro strapping, whatever your choice of poison is. Get a bag full of the stick-on pull-tie holders at Radio Shack too. They come in real handy routing stuff around.
Don't bind multiple cables tightly, just enough get them routed where you need them to go.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
I don't!:D I just let them hang out behind the racks. Whoever doesn't like it can fix it!:DMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I use zip-ties for mine.
I zipped all the power cables together and all the interconnects in bundles along their route.
My coax signal cables are bundled together.
I basically tried to keep them neat as possible and keep the power wires away from the signal wires away from the cable wires ect. ect.ect.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Yup... tie-wraps wll do it, but keep the power cords and the IC"s out of the same bundle and as far apart as practical.
One afterthought.... 3M's painters tape might be a nice alternative...More later,
Tour...
Vox Copuli
I use a couple of these. I always make sure to try and keep the power cables away from everything else.
cfrizz wrote:I don't!:D I just let them hang out behind the racks. Whoever doesn't like it can fix it!:D
oh that's just plain nasty...:DSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Tour2ma wrote:Yup... tie-wraps wll do it, but keep the power cords and the IC"s out of the same bundle and as far apart as practical.
to add to Tours recommendations, also keep non-fiber optic digital cables away from analog IC's.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
