Towers??
edited March 2006 in Speakers
Hey, im having such a hard decision with my towers, what would sound better the rti 8s with a psw505 sub or the rti10s with a psw505 sub. The big question is that if i have the psw505 i do not need a lot of bass from the towers, so what would sound better?
Post edited by schmilnik on
Welcome!
    edited March 2006
    What's your listening preference? HT, music, gaming (50%/25%/25%?)?
    edited March 2006
    Depending your preferences you must choose the correct towers.
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
    edited March 2006
    What do you plan on driving these towers with, and do you plan to run them on "large"? If your setting them to small and setting the crossover point at 80Hz both speakers will have similar low end output, making the case for the 8's. While the 10's are capable of digging lower than the 8's, without the proper amplification it will never be realized. If your using a receiver I suggest getting the 8's and let the 505 carry the low end.
    Proud SOPA Member since 2005!
    edited March 2006
    What's your listening preference? HT, music, gaming (50%/25%/25%?)?[/Q
    That is right on about 50 ht 25 music 25 gaming
    edited March 2006
    I would be using a receiver, but if i were to use an amp what would that cost me?
    edited March 2006
    This is a loaded question.
    An external amp will cost between <$1.00 used to >$500,000.00 somewhere in the world.
    Go listen to them and see which ones you like, pay attention to how they are hooked up in the store and note the difference between their set up and yours.
    When you get them home see how you like them with your system and upgrade as necessary.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
    edited March 2006
    Uh... nevermind :D:D:D
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
    edited March 2006
    The 8's will sound better. If you are using a good sub the low end of the 10's becomes a moot point. Many feel the 8's just sound better overall anyways, but not all... And Im sure im not the only one saying this but at the risk of giving you an answer your not looking for, get an SVS, not a polk sub. Their much higher quality for a better price. Go 8's with an SVS.
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
    edited March 2006
    SVSound.com for the subs...
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Yamaha HTR-5740 AVR
    edited March 2006
    Thanks that was the exact answer i was looking for!
    edited March 2006
    I have the RTi8's and have never once felt I was missing anything from my HT. You won't regret it, just get a super good sub!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
    edited March 2006
    Do you think the polk psw505 would do the job?
    edited March 2006
    If you don't already have the PSW505, is sounds like you would get more sub for your money going with an SVS. I've actually never heard one, but they are quite popular here. I have a Velodyne that I listened to in comparison to a Polk and Infinity sub at similar price points and the Velo blew the others away whether it was music or movie. I am very happy with my Velo. I haven't heard HSU either but they are highly recommended on this forum. I'm sure others will chime in about SVS and HSU......
    ...I should have read the entire post...didn't see the SVS recommendation above....
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
    edited March 2006
    What do you guys think of the psw505?
    edited March 2006
    I can tell you the response you will get from almost everyone on the forum.
    Polk does not make good subs!!! (comparitively)
    Now, the next thing people are going to tell you is that you should get an SVS.
    I personally would agree. I recently upgraded from my PSW303 to a SVS 20-39 PCi. There is no comparison. I would asume the 505 is similar. If you dont already have the 505 spend $100 more and get yourself and SVS. Your saveing some money going with the RTi8's anyway. E-mail teh guys at SVS and they will happily help you choosing the right one. Great guys great service. Send em an e-mail!
    Good luck,
    Jake
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
Welcome!
Welcome!
