Surround Bar/Sub Phase
wfoulds
wfoulds Posts: 7
Just purchased a Surround Bar and a 505 sub. I have the sub connected to the left and right front speaker inputs on a Yamaha HTR-5890 receiver.
I've hooked the black wires from the Surround Bar to the negative terminals on the receiver (red, blue, green, etc. to the postive terminals). Is this correct? It shouldn't matter as long as it's consistent among each connection from the Surround Bar...
I also have the two connections from the Sub. Would it make any difference if the sub is out of phase with the Surround Bar? The current sound quality is fantastic. I'm just trying to understand the impact of having the Surround Bar wired backwards.
Thanks,
Will
Post edited by wfoulds on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2006
    If the sub is about the same distance from your seating as the bar, they should be wired in phase. Wiring out of phase works when the distance changes so that time alignement is an issue and sound cancellations occur. It doesn't hurt to wire anything out of phase, it simply means that when one speaker is moving out the other is moving inward thus 2 speakers in the same plane tend to cancel each other when out of phase.
  • iworkfortweeter
    iworkfortweeter Posts: 53
    edited April 2006
    thats fine, as long as it sounds good to you its good. it won't hurt anything if that's your question...
    happy day!
    currently in car:
    '00 Honda Accord LX V6
    AEM V2 cold air induction
    c400.4 amp powering a pair of momo 6500's
    and a pair of momo 6x9's
    alpine monoblock amp powering a jl w3 12''
    custom fab work for tweeters
    jl rca's, dist block and power/grounds
    alpine cda 9857 head
    three ground loop isolators
    ipod integration, all songs at 320kbs
