4 ohm Center Channel OK?
I am "re-speakerizing" my 5.1 HT system and I need a temporary center channel until I can save enough money for what I really want. There is a center channel I'm considering that is 4 ohms. My other speakers (bookshelves) are 8 ohms and they'll be powered by a Pioneer Elite 52TX receiver. I play movies below reference volume levels. Should I be concerned about a 4 ohm center channel in this configuration?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
If your receiver can specify the loads for each individual channel, yes you can do it.
I know from my experience on AVRs that there is one setting 4 to 8ohms to specify for all speakers.
Or you can have powered by an amp.
