passive sub with several issues...
doggie750
Had read this link
http://www.polkaudio.com/forums/showthread.php?t=17954&highlight=passive
Need more details..........
Option of purchasing this.http://www.craigslist.org/pen/ele/140769980.html
Case1a: Passive 4ohm sub, using a 8 ohm receiver (since
all speakers are in 8 ohm). Worst scenario?
Case1b: Same sub using 4ohm receiver....
NOTE: for cases1 aren't feasible!!!!.....Receiver has preamp so I need an AMP...let's go to case 2
Case2: Same sub with Carver m1.5t mono amp.
Gain, freq, crossover,...etc control...HOW?
Should I get a amp specifically for sub?
(madisound.com)
Case3: Forget about this sub?
This is sub is down to $170.
HELP asap
Other sub options:
DCM KX 2
PSW350
(madisound.com)
HELP asap
Other sub options:
DCM KX 2
PSW350
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Forget Case 1. No option for connecting to receiver alone.
Case 2 gives best bass.............Passive subs require a separate amp. The sub output of your receiver is line level (low power)and goes into the amp that drives the sub speaker. The crossover unit in your receiver for that sub output will work fine to help accomplish this.
Case 3 looks best to others since big DIY subs are a turn off to many and alot less hassle and tuning.
The sub in the listing looks to be alot for the money.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis.........I dont quite understood what you mean by this........please advise.
Mike,
Those amp are sweet but aint got the $$$.......
Decent sub for <$200....what sub do you suggest?Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
I think he's trying to point out how diy subs can prove a much better bang for your buck than a retail sub since you have to deal with more things than just taking it out of the box and putting it in a corner.
Check out the plate amps at parts express ~ link. It'll add to the cost but you might be able to get by with something a little less powerful than what I first linked to...
At a budget of <200 you might consider saving a little bit. It's hard to get a decent sub for that price range, but if you held off for a little bit and bumped that price range to around 400 you could get something really worthy of the money. -
Hi doggy750,
The description and picture of the sub looks impressive. I don't think you'll find many subs in that price range with real maple veneer and heavily braced and damped. Can the seller tell you if it's a sealed sub and what the f3 is?
A couple issues I see are:
The sub is big so you should take acceptance factor into account (ie. will it fit in the intended space and such). Will it overpower the room?
You're F3 on that is probably in the neighbourhood of 25-30 hz (guessing and could really be off here). It's not going to rival a SVS but should be adequate and comparable to the psw350 I think.
Set up will be limited. You probably will not have control over phase, high pass/low pass and will have to depend on what's available from your receiver.
Something like a paradigm X30 controller would give you those controls but then you're spending more money.
You'll need an external amp or sub amp. I don't think you need gobs of power if your expections are in line with a PSW350.
I think you're getting really good value at the price (based on some assumptions) but you have to decide if you want to put in the extra time and dollars to get it set up and working really well. It's for your dad right?
You might be able to get a psw350 cheaper once you've factored additional costs.
regards
DaveTime is the best teacher. Unfortunately it kills all its students.
