Quick question...
Grimster74
Grimster74 Posts: 2,577
Anyone know where I can purchase a wall plate that will accept component video cables. I can find them that will accept standard a/v cables (video, audio left and right) but I'm just not sure if it will serve the same purpose. I would think they would but if I knew that answer I would not be asking this question. Thanks.
Post edited by Grimster74 on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2006
    I haven't seen a component plate, but you can customize your own from Parts Express. I've used the 2-8 jack plates with good results.
    Here are the component plugs and Decora Plate for them.
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=091-1211
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=261-404
  • Grimster74
    edited March 2006
    You are the man, that's exactly what I was looking for, thanks Dennis. I'm getting ready to install a projector and all the cables will be inwall so I just want to be able to plug directly into the wall by my a/v equipment. Thanks again.
    edited March 2006
    Radio Shack
