Rotel RB991 amp
GATOR3000
GATOR3000 Posts: 355
edited March 2006 in Electronics
Thinking of buying used Rotel RB991 200WPC@ 8 300WPC@ 4 2 channel THX amp to go with my present HT setup.
The amp would be powering my front Rti8’s through Denon 3806 preouts for now.
My question is:
  1. Would this amp make a noticeable upgrade for my present HT setup?
  2. If I play music through my Denon’s 2-channel pure direct setup would the source of music go through the Rotel only? Meaning bypassing Denon’s circuitry or would the music source come out through Denon?
  3. Is Rotel RB991 bright/forward or subtle lean back amp?
  4. Planning to get Lsi15 for stand-alone 2-channel rig. Would Rotel RB991 be OK with Lsi15?
Thanks in advance.
All your help/suggestions would be appreciated. :)
Gator
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre
Post edited by GATOR3000 on
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2006
    Hi Gator, the Rotel amp would be a GREAT addition to your setup. All speakers enjoy getting lots of current fed to them. My 200 watt Parasound amp made a huge difference in my system. I started hearing stuff on my cd's I had never heard before!
    Get the amp!
  • Skynut
    Skynut Posts: 2,967
    edited March 2006
    My Sherbourn amp did the same.
    More power and cleaner sound.
    Plus it will make the pre/pro upgrade easier when you get to it. :D
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • GATOR3000
    edited March 2006
    Thanks guys. Can anyone answer questions 2. and 3.?
    Theatre System 5.1
    Original A8T CD
  • EricT43
    EricT43 Posts: 130
    edited March 2006
    Direct mode on the Denon will still go through the Denon circuitry, such as the volume control, bass management, etc.
    Direct mode will bypass DSP modes and tone and balance controls. You don't want it to completely bypass the Denon, otherwise you won't be able to control your volume or cross over to your sub if desired.
  • GATOR3000
    edited March 2006
    Thanks Eric. That makes sense. I understand the volume and the cross over, but will it bypass the Denon’s amp and will the source be amplified by Rotell only?
    Theatre System 5.1
    Original A8T CD
  • cfrizz
    edited March 2006
    Yes!
    Let me clarify. If you get a 2 channel amp for your 2 front speakers, then the Rotel will handle only those 2 speakers. All other speakers will still be powered by the Denon.
  • GATOR3000
    edited March 2006
    YES...........now I got it. Never hooked up external amp to my rig and want to make sure I do it right. Guess we all have to start somewhere.
    I put my gear together with help and advise of this forum and it works well so far. Thanks guys! :)
    Gator
    Theatre System 5.1
    Original A8T CD
  • EricT43
    EricT43 Posts: 130
    edited March 2006
    The internal amps will not really be "bypassed" when you hook up an external amp. They will still receive a signal. But, if there is no speaker connected to the internal amps, then there is no load, and therefore the amp is not doing anything. So it's sort of on "standby".
  • venomclan
    venomclan Posts: 2,467
    edited March 2006
    Rotel amps tend to be on the laid back side with a touch of warmth. They are the same company as B&W and Classe. Check out the Rotel forum at htguide.com
    Venom
  • GATOR3000
    edited March 2006
    I will check out htguide.com. Venom thanks for the link. I find the Rti8's on the bright side for music. Glad to hear Rotel is on the warmer side.
    Cheers
    Theatre System 5.1
    Original A8T CD
