what amp???
dangerranger
allright im buyin a 12 inch polk momo and im putting it in my ford ranger my question is what amp will give me the best sound and make my sub hit.price is not a prob.its between a Kenwood KAC-7202 or Profile AP1000.thx
Post edited by dangerranger on
A MM2124 is rated to handle 400 RMS. Thats the size of amp you should be looking at.
Out of the two brands you listed, I like Profile best.polkaudio sound quality competitor since 2005
ya i know but i cant find a amp on crutchfield that 400 thats around 200 i think the closest was a like 500 bucks.but if i got the profile and turned the gain around half it should be ok shouldent it
The AP1000 is a good choice. It makes 480x1 at 4 ohms which while being more than the sub is rated, with proper gain adjustment and some commone sense with the volume youll be just fine.polkaudio sound quality competitor since 2005
or how about this get 2 12 inch momo and a ap2000 puts 2x480 at 2 ohm rms and 2x320 at 4ohm rms so i could push 320 to each and be fine and would still sound good right???
dangerranger wrote:or how about this get 2 12 inch momo and a ap2000 puts 2x480 at 2 ohm rms and 2x320 at 4ohm rms so i could push 320 to each and be fine and would still sound good right???
Can you get DVC momo subs? if so get dual 4 ohms and wire them to 2 ohms to send 480 rms to each one, but keep the gain LOW, because as far as I know momos don't like to be overpowered if you're going to crank up your rig all day long...<|>
