Timber/Vocal Matched Speakers for RC60i
jwagh
jwagh Posts: 1
edited March 2006 in Speakers
I have a pair of RC60i speakers and am looking for the matching center, right, and left channels. I was told that the CS1 and CS2 matched the RC60i rear surrounds. I am unsure that this is correct. I appreciate any help you can give me. Thank you for your help!
  • okiepolkie
    okiepolkie Posts: 2,258
    edited March 2006
    You were informed correctly.
    The RC series timbre matches well with the Monitor series.
    TC series with the RTi's.
    LC's with the LSi's.
    That isn't to say you can't upgrade your fronts to the RTi's if you want. Remember that your surrounds are primarily used for ambient sounds, so you won't notice a huge difference in their tonal characteristics. I have noticed a big difference when using different speakers throughout my front stage, but there shouldn't be much problem with the rears.
    BTW, welcome tothe forum.
    Hope we help.
    Tschüss
    Zach
