VPI 16.5 owners....question
TroyD
Has anyone had a problem with the suction tubes breaking? I've had two break on me so far.... any ideas what I could be doing wrong??
BDT
BDT
Post edited by TroyD on
Mine are so thick and strong I can't imagine how one would break. Are you talking about the clear tube with a slot? Do you have a pic?
yeah, the clear tube, twice, snapped clean off where it inserts into the tube holder.
I've ordered a new tube and holder just for **** and giggles but this is pissing me off.
I'll take a pic...I plan for the future. - F1Nut -
here is a pic....
The short end is the part that is inside the tube holder, it's sheared off both times.
Troy, save that piece I have an idea for a replacement......but i'll need to getome accurate id and od measurements.
Troy,
Have not had that problem, of course, the whole sucking thing has all kinds of "random thoughts" going.
You bought a new 16.5? Seems the tubes would be fine, as Max said the one I got with mine the tube is very thick, the instructions said something about turning the tube opening a little bit from straight down, I did that and have not had any trouble so far.
RT1 -
I dunno, I'm at a loss.
I emailed VPI just to see....but I can't think of a reason why it would do that. It could be just a bad couple of tubes..
Might be those fumbling stubby fingers...:p
Your tubes just don't suck....."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Checked another forum and it seems to happen relatively infrequently.... one answer was to remove the tube assembly between cleanings something about the spring tension during storage. May be a quality control issue also as some had broken/cracked during long periods of storage.
Wow this is really odd. I have had my maching now for just over a year and have never had this happen. Hope you find a solution.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Could it be a production problem with a small score around the tube? Remember, with that type of material a score weakens it significantly to the point where you can snap it apart. I'll take a look at the two I have.
I got an email back from VPI, I have to lower the height on the ring, apparently the tube is taking the full force (which I didn't pay attention to) of the suction. I didn't know that there was an adjustment on it until now.
