citation 16 amp?
dagame27
Hey guys I was planning to buy some SDA's in the near future and was wondering if this amp is sufficient to drive them. I can't seem to find the specs for this amp and I found a deal on one of them, so I am curious. Thanks
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
The 16 was rated at 150-170 WPC depending on the version. They were brutes and still very highly thought of.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
HK's love low impedance. My AR-9's are pretty difficult to drive. Several years ago when I went to purchase them, the owner had been driving them for years with a 60wpc @ 8 ohms HK Citation 12.
That's a nice amp, a buddy of mine had one and sold it a few months ago. If the price is right, go for it. Those are cool led's on there too!Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
I had a citation 16 for quite a while and used it to drive a pair of SRS-SDAs. I didn't have any problems and the amp has plenty of power. I believe that it was high current (enough to weld with) and it was made in the USA. The only complaint that I had was that it was a bit heavy on the low end or not crisp enough on the high end. I now power (bi-amp) the SRS-SDAs with a pair of PSE mono-blocks on the bottom and a PSE stereo on the top. They sound cleaner but then the amps cost a lot more than the 16. The citation 16 is a great amp for the money. The FM tuner (I think it's the 18) is also a great piece. I have one and it still sounds great.
Good Luck, Phil -
Phils "not crisp" is someone elses "warm". The HK solid state amps were voiced after their Citation tube amps of the 60s. This was the HK sound. I too find it a little soft on the highs especially with Polk speakers that tend to also be softer in the highs than other speaker brands. It isn't muddy by any stretch, but the solid bass and midrange are more pronounced than the highs in all of the HKs that I have owned. I still have a Citation 24 that I use on occasion.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I didn't mean to say that the 16 was a bad sounding amp. I also have a 22 or is it 24 (200wpc) that I use in another system where the speakers are quite bright and weak in the low range (6" woofers). I also still have the matching pre and tuna in the 20 series. The tuna is one of the best I have ever used. So I didn't mean to sell the citation equipment short - it is good stuff and priced quite nicely.
Phil -
You must have the 22. That is a beast, with some way cool lights........HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
It sounds good too. It looks way cool when I stack all three of the pieces in the same system. As a side note the 16 always sounded like it had more guts than the 22 even though the power rating was lower. I think the 22 had a quicker responce time and overall suonded a bit better as I sold the 16 and kept the 22. I replaced the 16 with a pair of Mac 250s modded, bridged to mono. They have a similar sound to the to the 16 but I think they have a better sound and even more guts. Some of the vintage stuff is cool and often doesn't cost a bundle.
Phil
