Denon DVD gurus...I have a question
steveinaz
steveinaz Posts: 19,545
edited March 2006 in Electronics
I don't do surround, my Denon 2910 will be run strictly 2-channel, so here's my questions:
Do you see any problem running the digital coax out for Redbook CD playback, and running the regular RCA outs for SACD/DVD Video/Audio?
Can these connections be made simultaneously?
I was going to run the R/L analog out from the 2910 to my "SACD" input on my preamp; and run the dig coax out from the 2910 to my DAC, DAC to "CD" input on my pre. Does this sound good?
I would end up with my preamp inputs being:
"CD": My external DAC (Redbook CD)
"SACD": SACD/DVDA/DVDV
Post edited by steveinaz on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2006
    I assume you mean using the 5.1 analog RCA outputs and not the standard l and r ourputs?
    That's how I have the 2200 in my bedroom set up, and it works great. I have the SACD outputs running directly to the receiver, and the digital output running to the Para DAC...
  • PolkThug
    PolkThug Posts: 7,532
    edited March 2006
    I'm pretty sure you can, I've got both hooked up on my 2200.
  • steveinaz
    edited March 2006
    I meant the regular 2 channel L/R outs, is that ok? (I'm 2-channel only setup)
    I don't have to use the 5.1 connections for SACD do I?
    billbillw Posts: 7,596
    edited March 2006
    Steve, Your plan should work perfectly. I would use the L/R connections in the 5.1 output and set the menu to 2-ch (SRS OFF)
  • AsSiMiLaTeD
    edited March 2006
    I think you should be able to use the regular analog outputs for stereo playback - I can on my 2900. Here's the easiest way to find out though:
    Grab a SACD that is NOT a hybrid (does not have a regular CD layer)
    Try to play it through your digital output - you should hear nothing, this just confirms that it's a true SACD only title and there's no CD layer, making that variable a known
    Try to play the disc through the RCA jacks you're talking about. If it plays, then you're getting SACD playback through those jacks, since there's not a CD layer on the disc
    I think you already know that and were just looking for confirmation that you could use both sets of jacks at the same time - which the answer is yes
  • steveinaz
    edited March 2006
    Cool. You would think that SACD would be output at both sets of RCA analog outs; 2-channel and 5.1 (Mains). Provided you've setup your audio that way in the DVD's setup menu...
    Thanks guys.
