One BIG Sub
janmike
janmike Posts: 6,146
Here's one for you!
"Liquefied innards anyone? Just stand next to Richard Clark and David Navone’s little creation when it’s on full steam: a 60inch subwoofer. Here’s some quick specs.
The cone moves 6 inches peak to peak under full-tilt output.
The actual cone diameter is 54 inches, with the 3 inch wide surround on the outside of that. The radiating surface area is 2,290 square inches. That yields a one way displacement of 6,871 cubic inches. That is equivalent to the displacement of 161 ten inch woofers that move 1.5 inches peak to peak.
The motor is capable of producing 6,000+ pounds of linear force, which is necessary when considering the very large surface area and displacement volume required to produce high SPL levels.
The woofer was designed with the capability to produce SPL levels of 188 dB."
Michael ;)
NORTH of 60°
Post edited by janmike on
  • janmike
    edited March 2006
    This one is for you Sid.
    "No, it’s not a fan. That, ladies and gentlemen, is the world’s most powerful subwoofer: the Eminent Tech TRW 17. Rather than your garden variety 10 or 12 inch paper cone pulsating back and forth, this subwoofer creates a wall of air as big as your living room. In other words, the entire room becomes a resonating box!
    By rotating the fins and modulating the speed, frequency goes all the way down to 1Hz, the territory of jet engines, nuclear explosions and plate tectonics. By comparison, your typical sub hits 20Hz on its best day.
    With a price of $12,900, the TRW 17 is for rap superstars only. Rumor has it smaller versions are in the works as well as one model specifically for cars — naturally, you must present your rap superstar ID at time of purchase."
    Michael ;)
    NORTH of 60°
    VR3 Posts: 29,567
    edited March 2006
    Everytime I see that lil fan subwoofer...
    I keep imaging those lil 3" fans that sit on top of your dresser and do basically nothing but make alot of noise because its trying so hard to actually do something...
    I know its bigger, but I laugh when I see a pic of it...lol
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    Everytime I see that lil fan subwoofer...I keep imaging those lil 3" fans that sit on top of your dresser and do basically nothing but make alot of noise because its trying so hard to actually do something...
    Exactly. There's a reason they mention the rap superstar thing. That thing will probably move a lot of air and sound like a lot of hot air.
    "God grooves with tubes."
  • G-force
    G-force Posts: 82
    edited March 2006
    Yes you know you have a serious sub when the port is a 3'x3' hole in the room's floor or ceiling.
    VR3 Posts: 29,567
    edited March 2006
    You know you have a serious sub when it can double as a air conditioning unit...
    HAHAHAHA!! Seriously...I bet that fan sub will...blow me away!! HAHAHAHA!
