Hdcd?
jayman_1975
jayman_1975 Posts: 672
edited March 2006 in Electronics
is anyone very familiar with HDCD?. If i have a reciever that has it, do i also need to get a dvd or cd player that has it as well in order to benifit at all from this feature? Also. this Denon Link thing, anyone know if it's worth while getting the DVD player that supports it?, my reciever has it but don't know how much better sound you get with it vs optical cable. Maybe the difference wouldn't be noticable anyhow as i am only using monitor series speakers. Any thoughts?
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Post edited by jayman_1975 on
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    edited March 2006
    I never heard...do you have any link of that HDCD ???
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • jayman_1975
    edited March 2006
    try having a look at this
    http://www.hitbutiken.com/hdcd/?p=hdcd
    Arcam CD37
    Vandersteen V2W
    heiney9 Posts: 25,498
    edited March 2006
    HDCD was one of the first higer resolution formats to appear I'd say around 1995 (don't quote me on that). Originally developed my Pacific Micronics, it used an additonal chipset inline with the DA section of a cdp, stand alone DAC, and apparently some AVR's. There are titles available in HDCD, some say it on the liner notes some don't. I don't think anything new has been released in HDCD. It is of benefit, but certainly not worth seeking out and paying top dollar for. The nice thing is you can play regualr cds in an HDCD unit and it has no adverse affect.
    The technology has since been bought by Microsoft and I have no idea what their plans are for it.
    Here's a link to get you started. Typical Google search shows some results
    http://timefordvd.com/ref/HDCD.shtml
    edited March 2006
    What the hell....here's more info. See you didn't even have to use Google :D
    HDCD (High Definition Compatible Digital) is a digital encoding and decoding process for compact disc and DVD audio recording. The HDCD process manages to encode 20 bits of audio information into a conventional CD 16-bit channel, yielding a greater dynamic range and a more true-to-life sound when decoded. HDCD was developed by Keith Johnson and Pflash Pflaumer between 1986 and 1991, and made publicly available in 1995. Johnson and Pflaumer went on to found Pacific Microsonics, which was later acquired by Microsoft. Since 1995, more than 5,000 HDCD recordings have been released and more than 175 of those have been nominated for GRAMMY awards. An article in Wired Magazine hailed HDCD technology as "the greatest single advance in digital reproduction to date."
    Audio chip manufacturers including Motorola, Sanyo, and Zoran have developed HDCD chips for audio products, such as CD and DVD players and receivers. HDCD-encoded media will play on machines that don't have the chip, and HDCD-equipped machines can play traditionally recorded media. Because the decoder chips include a high-precision digital filter, HDCD-equipped players will improve audio quality for even traditionally recorded CDs and DVDs. Conversely, because of the recording process, HDCD-encoded media will also sound better than traditionally CDs and DVDs on players that don't have the HDCD chip. Nevertheless, the best audio quality is yielded by HDCD-encoded media on an HDCD-equipped player.
  • Danny Tse
    Danny Tse Posts: 5,206
    edited March 2006
    If you have a receiver that can decode HDCD, just run a digital connection from the DVD player or CD player to the receiver and the receiver will do the HDCD decoding.
    Denon-Link? That's a digital connection to pass along hi-rez signal, as in SACD and DVD-A, using one single cable. That can also be done with HDMI v1.2.
    HDCD-encoded CDs are still being released. On some hybrid SACDs, the CD layer can also be HDCD-encoded. However, whether a disc is HDCD-encoded or not is often not marked on the packaging or the disc....and you won't know until you put the disc into a HDCD-capable player. Or use Windows Media Player V.9 and up to play the disc.
    Here's a ongoing thread at head-fi.org that tries to identifies HDCD-encoded discs that weren't posted at the now-abandoned HDCD.com website.
    billbillw Posts: 7,800
    edited March 2006
    To answer one of your questions (if it wasn't clear yet), you don't need anything except a CD or DVD with digital output. In otherwords, use the digital coax or toslink to connect and let the receiver do the decoding. It will automatically detect an HDCD disc and start decoding it. It is a noticable improvement on discs that are decoded.
  • danger boy
    danger boy Posts: 15,722
    edited March 2006
    HDCD has been around for years... google it. and you should find lots of good explanations of it.
    PolkFest 2012, who's going>?
  • danger boy
    edited March 2006
    so to get HDCD you need an HDCD player right? If your receiver has a HDCD chip in it.. it will not decode it right? Since the decoding takes place in the player, not the receiver? ok
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2006
    Disregard...
    edited March 2006
    No, apparently some AVR's with DAC's in them also have the HDCD chipset as well. Pacific Micronics invented the HDCD algorythm and others developed their own later on. HDCD decoding is part of the DA process so anything that have DAC's can potentially have HDCD decoding. It's an additional chipset in addition to a high quality digital filter.
    edited March 2006
    DB, did ya read post #5 :confused:;) . You have to route the digital signal via the digi output of your player thru the AVR DAC to get HDCD decoding from an AVR that has HDCD capability
  • danger boy
    edited March 2006
    ok it doesn't make sense. but i got it now. thanks.
  • jayman_1975
    edited March 2006
    "Denon-Link? That's a digital connection to pass along hi-rez signal, as in SACD and DVD-A, using one single cable. That can also be done with HDMI v1.2."
    Ok i think i have the HDCD figured out..now is it worth buying a DVD player that has the denon link to match up with my Denon reciever. Will this give me better sound than a good fiber optic cable?
    Arcam CD37
    Vandersteen V2W
    edited March 2006
    Why? Maybe if I know where your confusion is I can try to make it clearer.
  • jayman_1975
    edited March 2006
    i'm looking to put a nice dvd player with my Denon 3805...but i dunno how much i should spend(looking to match). I would like to get the best possible picture but not sure how far up the model line i have to go to get that but not chase a bunch of other feature that will not be doing me much (ie. HDCD and Denon link). I have a 42in sony grand vega HD so i wanna put the best signal to it i can as far as DVD goes. I do have HD satelite as well so maybe i'll be dissapointed in pic quality no matter which DVD player i get.
    Arcam CD37
    Vandersteen V2W
  • Toxis
    Toxis Posts: 5,116
    edited March 2006
    get the denon 3910. Denon link sounds great! But if that's out of the budget, the 2910 sounds every bit as good IMO but you just have to use the 6ch analog cables out to get SACD/DVDa playback. Personally, I have the 3805 and the 2910 and only use the 6ch out. I disconnected my digital coax because I felt the processor in the 2910 sounds better than the 3805 anyhow.
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    Does anyone know if there is a replacement (i.e., upgrade) for the Burr Brown 1732 DAC with HDCD decoding? Since this DAC debuted in 1998-99, I was wondering if it had been updated yet.
    "God grooves with tubes."
    edited March 2006
    Can't say I've heard of that designation. The original Burr Brown DAC w/ HDCD was the PCM 1702. It appears Burr Brown was aquired by Texas Instruments and I've been poking around the site and don't see a PCM 1732 on their list. Best I can find....take a look for yourself and see if you can get more info.
    Ironically the 1702 is the only single channel chip they show, all the rest are 2 channel or multi-channel on one chip (not ideal). Must be more info somewhere because I know for a fact they still produce the PCM-63K. Yep I see the PCM-1732 in the Stereophile review
    http://focus.ti.com/paramsearch/docs/parametricsearch.tsp?startIdx=1&endIdx=10&familyAliasId=1100582&familyId=582&uiTemplateId=NODE_STRY_PGE_T&sectionId=null&tabId=null&totalCount=68&showAdditionalParameters=no&lc=3000166&lc=3000195&lc=2000084&lc=2000480&lc=2000305&lc=2300088&lc=2200348&lc=2000089&lc=2001192&lc=2000494&lc=2001130&compare=yes&download=yes&sort=yes&customize=yes&paramResults=yes&paramCriteria=yes&familyTree=yes&military=no&baSystem=yes&paramTable=no&sortOption=&sortMode=&searchPaths=1100582&pageId=undefined&startIdx=1&endIdx=10&templateId=0&navigationId=0&family=analog&paramTable=no&military=no&ul=DSD1796&ul=PCM1600&ul=PCM1602&ul=PCM1602A&ul=PCM1604&ul=PCM1606&ul=PCM1608&ul=PCM1609A&ul=PCM1680&ul=PCM1702&&uiTemplateId=NODE_STRY_PGE_T&sectionId=null&tabId=null#rt
    edited March 2006
    Here's yet another source of HDCD info. It's an older .pdf but it may help explain things a little better, lots of pics :D
    edited March 2006
    Here are data sheets for various Burr Brown DAC chipsets. EarlyB you may find what you are looking for in here.
    http://www.datasheetcatalog.com/burrbrown/35/
    edited March 2006
    It appears after looking at the data sheet for both the PCM 1702 and PCM 1732 that the latter had the HDCD decoder built into the chip. The former was strictly a single channel DA chip and the Pacific Micronics PDM-100 was a seperate chip along with the HQ digital filter needed. It also appears the PCM-1732 is as far as they went with HDCD. Looking at all the data sheets for DA chips after that, no more have an HDCD designation.
