I need some floorstanding speaks to match my rt55
I have a pair of rt55 bookselve speakers that I want to keep as my rears. Which fronts would match the best?
Post edited by yoakly on
I also have a cs245 center speaker
Assuming you want floorstanders, I'd say RT800's. Or, you could always just pick up another pair of 55's. Though I like both speakers, there's not a significant difference in the sound of the two. The 800's might go a little deeper, but not much. Going higher in the RT line, you get into the powered speakers (which I don't really like), like the RT1000p's.
If you can find a pair of RT800, they would be a perfect match.
Should I get a different center speaker?
yoakly wrote:Should I get a different center speaker?
Only if you want to spend more money. If you did, a CS400 would have better timbre match, but the CS245 is from the same series. -
One more question. What is a good $2-300 receiver for home theater with these speakers? Thank you for all your help
