DVD face-off: Marantz DV-7600 vs Denon 2910
steveinaz
steveinaz Posts: 19,545
edited March 2006 in Electronics
I can get both for $699 NIB. I realize the Denon has better potential in video department, but I also know the Marantz will nudge it out for sound quality (which is my focus). The Player will be run thru my DAC for DVD movies/CD's. I don't give a rats **** about SACD/DVD-Audio performance/features.
Please comment if you have one these players...
Post edited by steveinaz on
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2006
    Wouldn't the Marantz' better sound quality relative to the Denon be null if you run them both through your DAC? Or is the Marantz that much better on a transport level?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • steveinaz
    edited March 2006
    The DAC most likely makes audio a wash. I'd like to see the internal build of the Marantz, but can't find a "guts" shot anywhere. Denon has an internal shot of the 2910, I actually expected to see better build quality, but it's probably a non-issue.
  • audiobliss
    edited March 2006
    Those are supposedly of the Marantz.
    And then the Denon:
    There's a bunch of pics of the Denon here.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
    heiney9 Posts: 25,421
    edited March 2006
    Wow, I'm actually quite impressed with the internals of both units. I have had a few DVDp open and they were nowhere close to having so much internals. I especially like the 3 or more discrete circuits in each. The little transformer in each is still puzzling. My Pioneer DVDp has the same exact trans. Perhaps that's all they need.
    Steve, they both look like similarly solid units. I don't think you could go wrong with either. Head to head I bet they'd be so similar you couldn't tell the diff. Go with the one that has the best pic rating since you'll be running either thru your Benchmark.
  • steveinaz
    edited March 2006
    Yep, that's what I'm thinking...
  • HiPerf360
    HiPerf360 Posts: 436
    edited March 2006
    I would think they would be very similar as they are both owned by D&M Holdings and both use outsourced technology.
    I had a Marantz DVD player that I used for music before I got my Sony DVD-9000ES and it was a very good sounding unit. (Didn’t have progressive scan video).
    In fact I gave it to my father and he is using it in his system now.
  • steveinaz
    edited March 2006
    Denon 2910 on the way via Crutchfield.
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2006
    Sweet!
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • steveinaz
    edited March 2006
    Wes, see your email. :D
  • peteran
    peteran Posts: 141
    edited March 2006
    I can't say about the marantz but the 2910 has improved considerably the audio of my cd's(2 chanel). Previously I owned Onkyo, pioneer and JVC. The Dymamic and clarity range this player produces haven't been able to hear before.
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    edited March 2006
    IMHO. Denon is superior. Better picture and similar sound quality.
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • steveinaz
    edited March 2006
    The audio from the Denon will been run digitally thru my Benchmark DAC, so I'm not worried about that aspect. I chose the Denon because it's video quality is rated higher.
