Yamaha RX-V2600 woofer hook-up
audio pirate
How do you hook up an Polk PSW 10 to a Yamaha RX-V2600? Found a splitter and hooked that up, so hope it works. Ciao,Bill
Mcintosh MX110 Mcintosh MC7200
Mcintosh C225
Yamaha RX-V2600
Olympus EV-SP12
Yamaha A720
Yamaha A1000 DSP
Yamaha E200 DSP
Bose 901/IV's
Bose 201's
Bose VC110
Marantz 120B
Marantz 1060
Sony Speakers and woofer (garage stuff)
Teac,Sansui, Pioneer dvd,and tape
XM radio
50"Panny plasma
Polk T90's,CS2,30's, PSW10
Mcintosh C225
Yamaha RX-V2600
Olympus EV-SP12
Yamaha A720
Yamaha A1000 DSP
Yamaha E200 DSP
Bose 901/IV's
Bose 201's
Bose VC110
Marantz 120B
Marantz 1060
XM radio
50"Panny plasma
Post edited by audio pirate on
audio pirate wrote:How do you hook up an Polk PSW 10 to a Yamaha RX-V2600? Found a splitter and hooked that up, so hope it works. Ciao,Bill
seriously dude, with that list of equipment that you "supposedly" have, you don't know how to hook up a "basic" sub to a receiver? use the sub pre-out and set your mains to large. or you could hook to the front left and right main pre-outs and set your sub setting to "none." experiement and see which gives you the best performance.
anyone who says they macintosh should know how to do this. just my .02...Jeff Rowland CAPRI | Yamaha RX-V3800 | Jeff Rowland Model 6 Mono Blocs | Technics SL1200 MKII | Shure V15VxMR w/ JICO Stylus | Sony SCD-XA5400ES | Monster HTS 2600 | Polk Audio LSi 15 w/VR3 Fortress Mod | REL T/9 x2 -
Yes Dude, I have had all my equipment in stereo stuff, for your information 901's don't need a woofer, the other sytem is Olympus speakers which also don't use a woofer, the garage stuff has a woofer that is the speaker connection set-up. The new Home theater thing is totally separate and my first experience using a "woofer" with a single "woofer" RCA plug on the HTR unit, my instructions with the Yamaha did not show using a splitter for the woofer single outlet, so I figured I would throw the question out as I didn't want to use the speaker set-up for other reasons. So thanks for the re-affirming the correct set-up. For further info I have DSP units wired into the systems with the Mac's so I can create different arenas of sound. Ciao, Bill;)Mcintosh MX110 Mcintosh MC7200
Mcintosh C225
Yamaha RX-V2600
Olympus EV-SP12
Yamaha A720
Yamaha A1000 DSP
Yamaha E200 DSP
Bose 901/IV's
Bose 201's
Bose VC110
Marantz 120B
Marantz 1060
XM radio
50"Panny plasma
