Bridged Amps - Monitor 10s
Modvlar
Modvlar Posts: 51
edited March 2006 in Vintage Speakers
Hi,
Just wondering... Is anyone using (or has anyone tried) bridged amps with their monitor 10s? Any stressing out with impedance?
I hopefully have a pair of hafler 9180's heading my way with the hope of using them as monoblocks. (now I'm thinking I should have just picked up a bigger amp)... Probably will be just fine, but after reading about how bridging cuts impedance in half... got a bit nervous.
Funny thing, as with an earlier thread that I had started, I just recently saw that hafler (and fosgate) studio monitors build light bulbs right into their crossovers for protection. I've gotta try it. Probably in the 150w range.
Curious.
Post edited by Modvlar on
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2006
    There are others around with better knowledge than me, however I can't recall anyone mentioning any impedenace issues with the Monitor 10's. I'd say unless someone comes up witha major red flag, do it to it! :D
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
    F1nut Posts: 51,686
    edited March 2006
    If the impedence of your speakers is less than 8 ohms, I wouldn't advise it.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2006
    I ran a pair of Rotel RB-960BX bridged mono on Monitor 7a's for a while, with outstanding results. You don't have much to worry about with 10's as far as impedance dips, rock on.
  • Modvlar
    Modvlar Posts: 51
    edited March 2006
    Thanks. Will give it a go.
    Probably the amps will just become extra hot space heaters. I'm going to be frying once summer comes.
    Hoping I get the amps soon... Wishing people closer around my area would ask fair prices for gear.
