Taking advantage of subwoofer out
BullShifter
BullShifter Posts: 66
On my subs there is an signal out. If I use a Y-splitter in the input and connect the receiver's output and subs output will there be any change?
What about splitting all 3 of the receiver's L/R & sub outputs into the sub?
Yes I know my subs aren't the greatest but with the Daytons and added poly-fil it's hard to beat for the money.
Since I'm the subjet of subs, what's your opinion of the best music sub under $1000? I've heard the SVS isn't the greatest in it's upper range. 2 of the Part Express 12" Dayton Titanic kits seems to be the best option or build my own from scratch.
Thanks for any help.
HK AVR 335
Polk R50 fronts
Polk CSi25 center
Polk R15 rear
2 Sony modded subs with 12" Daytons
32" Sharp Aquos
PS2
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    Build your own sub using the two 12" Daytons that you have already. Put both of them in a single box. All you need is some MDF and a plate amp. You can build an awesome sub for about $200. Search the 'net for a design that you like.
    "God grooves with tubes."
