Home Generator for back up power
HBombToo
HBombToo Posts: 5,256
edited April 2024 in Clubhouse Archives
I am meeting with a gentleman this afternoon regarding the installation of a back up power system for my house. I have a much experience with this from my current job ensuring our commercial switching systems are protected. However, I have no experience with home systems and I was curious if anyone on the forum could throw any advice my way. I have a meeting set up at 4 PM central today so your day help will be appreciated
Current base line for discussion is as follows:
Generac
fuel source is natural gas but subject to change.
6Kv for the initial discussion but if I hit about 4Kv I should be good.
Automatic tranfer switch.
Location of generator situated adjacent to the house but could move to a location in the back yard.
All considerations or distractions are welcome!
Thanks in advance.
HBomb
***WAREMTAE***
  • Demiurge
    Demiurge Posts: 10,874
    edited March 2006
    Generac is a great company, good luck
  • Early B.
    Early B. Posts: 7,900
    edited March 2006
    Cool. I've been wanting to get a Generac backup generator because the power goes out fairly often in my neighborhood. Can't provide any technical advice, but hope it works out for you.
    BTW, do you know if the generator will be noisy?
    "God grooves with tubes."
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2006
    Be sure and check with your local power company about your transfer switch. The cooperative where I currently work requires some external mechanism that our linemen can physically lock themselves and put a hot-line holdtag on. We don't want our linemen getting fried by current backfeeding through a transformer.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • bpadget
    bpadget Posts: 65
    edited March 2006
    You might want to consider a small ups (something more than your standard surge protector) on your sensitive electronic equipment.
  • seo
    seo Posts: 305
    edited March 2006
    I SO want a nat gas powered generator!!!
    I am envious.
    Signature goes here
  • Skynut
    Skynut Posts: 2,967
    edited March 2006
    I am interested in the total cost of instalation.
    please post updates for us.
    Good luck.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • unc2701
    unc2701 Posts: 3,587
    edited March 2006
    OK, the power off of mine is pretty dirty, so I'd put things like heat & cooling, plus the kitchen circuits on it. I'm pretty nervous when I put the TV on it, and the stereo isn't coming anywhere near it. The auto transfer is a waste of money, unless you're out of town a lot. Here, we loose power due to ice storms and hurricanes, so you've got plenty of warning. Depending on the power company, it's also a lot easier to have a manual transfer (you throw the switch and it's off the grid... no questions, no surprises). I'd go ahead and get the 6kva one. I'm guessing you have gas heat, so that's plenty to run the fan on it, plus a light circuit and the kitchen outlets. 4kva is gonna be a 15amp and a 20amp... not much to work with.
    Backburner:Krell KAV-300i
    F1nut Posts: 52,101
    edited March 2006
    They seem to prefer battery back up systems around here, dead quiet
  • jcaut
    jcaut Posts: 1,849
    edited March 2006
    Wes
    Regarding the above comment: I'm sure any reputable company will take that into consideration, and adhere to the local power company requirements. It's worth repeating, though, because I've had some dealings with backfeed and it's scary and incredibly dangerous.
    Jason
  • schwarcw
    schwarcw Posts: 7,360
    edited March 2006
    Henry,
    Make sure you get a whole house surge protector while you got the electrician there. I'm looking into a Honda gasoline powered generator. Very dependable, fast start, easy to service. There a little pricey compared to some of the cheaper ones. Batteries are okay if your just worried about a sump pump in a thunderstorm. But you want some real power to operate the airconditioning and the freeezer so you don't lose food or sleep if it takes the electric company more than 10 or 12 hours to restore power.
    When are you returning to the 'Burgh?
    Carl
  • Frank Z
    Frank Z Posts: 5,860
    edited March 2006
    Backfeed through your dryer outlet (208/230VAC). Kill the main breaker and only run the bare essentials (furnace and fridge).
    F1nut Posts: 52,101
    edited March 2006
    Henry, here's some info on the system I mentioned. http://www.bannerbackup.com/index2.htm
    It looks like it could be very expensive.
  • read-alot
    read-alot Posts: 812
    edited March 2006
    There was a power company employee KILLED by a dumbass homeowner doing this when he forgot to flip the main and run the juice to the pole.
    Needless to say the family of the deceased now owns the dumbass and everything he will ever hope to own.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • Frank Z
    edited March 2006
    Obviously there's alot more to the story and not having all the details makes it difficult to rebutt. Please note that I did say kill the main breaker in my post.
    Any electrical work can be deadly. If you don't know what you're doing...DON'T EFFIN' TOUCH IT!! If someone else could be injured, or worse, by your actions...DON'T EFFIN' TOUCH IT!!
  • nadams
    nadams Posts: 5,877
    edited March 2006
    Frank Z- I think the point is, that works fine unless you forget to flip the main breaker. Same thing with a manual disconnect.... that's why they came up with automatic ones. To save some poor linemans **** when Mr. Forgetful... forgets.
    Ludicrous gibs!
  • read-alot
    edited March 2006
    Alabama, July 14, 2005 - Sumter Electric Cooperative (SECO) officials report that a South Carolina lineman helping to restore power in Alabama after the damage caused by Hurricane Dennis was killed late Tuesday, reportedly by an improperly installed customer generator.
    According to SECO Director of Public Affairs Barry Bowman, the lineman was helping to restore power lost during Hurricane Dennis to customers in Alabama. The report Bowman received indicated the lineman was working on a power line that was supposed to be dead. It was not.
    “Tragically, the line this technician was working on was not dead,” said Bowman, “The line he was trying to repair had been re-energized by a customer who had improperly hooked up a generator and created a back feed of electricity from the generator into the supposedly dead line. The death of a lineman who was there to help the victims of Hurricane Dennis was the horrible result.”
    Bowman noted that the lineman’s name was not immediately released, but he was from South Carolina and worked for Pike Electric, Inc. in North Carolina.
    Alabama authorities are looking for the person responsible and indicate that charges are pending.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • unc2701
    edited March 2006
    Actually a properly wired manual transfer keeps this from happening- you can't get power from the generator without flipping it and if it's flipped, it can't backfeed into the main power lines.
  • nadams
    nadams Posts: 5,877
    edited March 2006
    Ah, my mistake, then. Still... the straight backfeed into the system method works, but it very dangerous if you forget to flip the breaker... that was the point of my post.
    Ludicrous gibs!
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2006
    Too bad those micro-turbines are still bloody expensive....
    Wes
  • unc2701
    edited March 2006
    yeah, outlet backfeeds are almost always a bad idea and I've seen some ghetto rigged transfers, that are probably what you were talking about.
  • read-alot
    edited March 2006
    I installed a propane powered electric start generator for my family back when I was on the road 33 weeks out of the year. The one thing my brother who had been a licensed electrician for 20 years preached was transfer switch.
    You just never know who takes our suggestions on this board and its possible that our suggestions to the wrong person could end up killing someone.
    Sorry for being so blunt but the Pike death got close to home.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2006
    Telephone line people need to check for a foreign voltage if not he / she is DEAD. They use foreign voltage detector for this purpose if they didn't and get killed the family may not get any cash for US for he **** forget.
    So my take F off if Electrical line People can't see foreign voltage because they don't use a device for this or they are not educated about this that who problem is it?
    Most people are not bright so line people need to be Brighter.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • read-alot
    edited March 2006
    Edit for the "edit".
    My friends out of Mt.Airy who work for Pike would love to come down to Florida and meet you the next time the wind blows your power away.Maybe then you will repeat what you have said here.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • madmax
    madmax Posts: 12,434
    edited March 2006
    Just wondering, if the lineman checks for voltage and there is none and he starts working on the line, what keeps him from being harmed if someone starts up a generator back fed improperly while he is working?
    madmax
    Vinyl, the final frontier...
  • read-alot
    edited March 2006
    Florida Steve probably never experenced an ice storm where the trees coated with frozen water make them as deadly as the power lines laying hidden somewhere under them.
    In that scenario you dont have to be the brightest bulb in the socket - you die anyway.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • disneyjoe7
    edited March 2006
    madmax
    Madmax,
    You have me rethinking my attitude if someone starts a generator / or any other power producing device wrong after he checked for voltage then he dead. Sorry maybe God has his or hers time clock shut off / done. Who are we to say when is when?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited March 2006
    Florida Steve is a northern transplant, who has experienced all kinds of "Ice Storms". But I do feel most are Bright where I lived before, many here are not.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • read-alot
    edited March 2006
    So maybe he **** forget happen cause he really didnt forget the ****?
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2006
    Many in Orlando are from where you're from.
    Wes
    (And yes, I know what the hell an ice storm really is.)
  • HBombToo
    edited March 2006
    Well after a brief walk through with the A.B. May consultant I was mildly taken aback from the price. I figured sub 3k for a 6KV system but after running gas lines and doing the electrical it came in at 4.6k.
    I asked the question regarding the tranfer switch and it does automatically open the house and prevent any back EMF across the power lines protecting the workers. "I figured it would but asked anyway."
    A 12KV system will run about 6.5k so for a comparison you get double the power for an approximate 50% increase in cost. The interesting thing is the bigger the generator is the natural gas requirement begins to exceed the capacity of a 1.5 inch gas run which will minimize your total gererator output. Frank could probably explain the ins and outs of this with more detail.
    So at the end of the day I will not be using A.B. May and will continue to search for a 6KV system for less than 3k. Not sure if thats possible but I'll try anyway.
    Thanks for all the comments.
    HBomb
    ***WAREMTAE***
