In-Wall 7.1 in new HT, What would you use??
Snagglepuss1318
Snagglepuss1318 Posts: 61
edited March 2006 in Speakers
Im in the process of wiring up my HT before the drywall goes up in a few weeks. I was looking at the Polk In-Wall speakers. The room dimensions are 22.5'x13'. I thought about using the LC265i for the center, and the RC85i for the fronts maybe. I really dont know. Could you help me out w/speaker placement and your recommendations... I need to get this wiring out of the way ASAP. OH! also, I was looking at the PSW505 for my sub. What kind of wiring do I need to run for this?? Someone told me to run Coax?? Thanks!
Post edited by Snagglepuss1318 on
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2006
    Welcome Snagglepuss!
    I believe that the speakers you want to use are from 2 different series. The LC265i is the LSI series & the RC85i is the RTI series. To have a seamless system you should use either all LC speakers or all RC speakers.
    These 2 series sound quite different from one another.
    Good luck.
  • Snagglepuss1318
    edited March 2006
    Ok, if you were to go all L series what other components would you go with?? R series?? What would you use all the way around the 7.1??
