bi amping Denon 3805
jayman_1975
jayman_1975 Posts: 672
edited March 2006 in Electronics
has anyone tried this...and if so how does it work?
http://www.audioholics.com/productreviews/avhardware/Denon-AVR3805_review04.php
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Post edited by jayman_1975 on
  • unc2701
    unc2701 Posts: 3,587
    edited March 2006
    Passive biamping has debatable benefit and even moreso when the two amps are using the same power supply. That said, knock youself out, it's worth a shot.
    Backburner:Krell KAV-300i
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2006
    In theory, you gain 3 db with the double power, in reality, when the bass amp runs out the mid/high does too since they are tied together.
  • RoosterD
    RoosterD Posts: 36
    edited March 2006
    I've done it on my 3805 with the LSi15s. I noticed that the bass was more defined. I'm no audiofile, (I should say that first) but I felt the 8" subs were a little muted, and the highs weren't as forward?without bi-amping. Maybe I'm not using the correct lingo, but the lows/highs were more responsive with it. I didn't notice much of a difference in the midrange.
    I owned the 3805 and the LSi15s for 6months before reading about this. It's a pretty simple procedure, I'd be interested in what you find. :)
    Denon 3805S
    Denon 3910S
    Polk LSi 15's
    Polk LSi F/X's
    Polk LSi C
    Boston Pro 10" DIY Sub
    Samsung 5678W DLP 1080P
    PS3
  • FicmanS
    FicmanS Posts: 134
    edited March 2006
    I've got my 3806 biamp'd, slight difference in my rig. Worth the effort I would say...
    Rockin' In My House :D
    Pioneer 50 inch Plasma TV
    Denon AVR-3806
    Denon DVD-1930ci
    Polk Montor 70's
    Polk PSW-12
    Polk CS2
    Polk Monitor 40's
    Sirius Satellite Radio, Monster 3500MKII
  • jayman_1975
    edited March 2006
    cool...i'm gonna give it a try..let u guys know how it turns out.
    Arcam CD37
    Vandersteen V2W
  • jayman_1975
    edited March 2006
    one more question ...is there anything other than removing the connector between the speaker terminals that i have to do to my M 70's in order to bi amp them?
    Arcam CD37
    Vandersteen V2W
  • FicmanS
    FicmanS Posts: 134
    edited March 2006
    Nope that's all I did, I just loosened them up and moved them out of the way. That way I would not misplace them...
    Denon AVR-3806
    Denon DVD-1930ci
    Polk Montor 70's
    Polk PSW-12
    Polk CS2
    Polk Monitor 40's
  • jayman_1975
    edited March 2006
    ok..one other question before i go to all the trouble...i can see the advantage of this when playing music in 2 channel but what happens to the H/T aspect...more power to just 2 speakers..wouldn't that make it a little irregular when watching in 5.1?
    Arcam CD37
    Vandersteen V2W
  • Dennis Gardner
    edited March 2006
    Once calibrated for the load change, you shouldn't see any difference when changing volume levels.
  • Toxis
    Toxis Posts: 5,116
    edited March 2006
    the 3806 is capable of doing this via the menu. The 3805 you have to completely rig like they showed on that site. If that's a feature you want, sell your 05 and move to an 06. Done.
  • jayman_1975
    edited March 2006
    i just bought my 05..and would probably lose half of what i paid a week ago to sell it...i've decided that i like the way it sounds just normal, i can crank the heck out of my monitors and they sound awesome so i'll just leave it at that. Besides, my room is not big enough to need a bunch of extra power(16*13)
    Arcam CD37
    Vandersteen V2W
  • jayman_1975
    edited March 2006
    well i decided to give it a whirl...i think that it sounds pretty good...much more base...and stronger highs...i think if i didn't have a sub i wouldn't miss it now. I would definitely reccomend it as long as you don't plan on using surround rear speakers.
    Arcam CD37
    Vandersteen V2W
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited March 2006
    I've done this with mine and definately noticed an improvement in sq. One thing to be aware of, some units you need to reverse the l/r inputs for SURR BACK / MULTI ZONE. I had mine hooked up correctly and heard things go L =>R while I saw things go R=>L. Turns out it's not an isolated issue.
    DJ
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
