Power strip
jcaut
jcaut Posts: 1,849
edited March 2006 in DIY, Mods & Tweaks
I know: A pretty mundane sounding project. Nevertheless, this turned out well enough that I wanted to show somebody.
I've been wanting a power strip that I could put on an audio rack with some other components. When I saw Partsexpress had these buyout rack-mountable strips for ~$17, I thought that was just the ticket, so I bought one. There weren't any dimensions listed, and when it arrived I was surprised to see that it was less than 4" front-to-back. Fine for rack-mounting, I guess, but not really what I had in mind, as I wanted to sit it On the rack, like a regular component. Maybe sit something on top of it, etc.
Anyway, I built a center section out of MDF to go between the front and back "halves" of the strip, to make it deeper, like a typical component. Finished it with the infamous truck bed liner, and a couple of strips of red oak for side panels. Re-wired it internally such that one receptacle is switched and the others are always on.
This proved to be a difficult thing to show in pictures, but it looks really nice.
Post edited by jcaut on
  • Early B.
    Early B. Posts: 7,900
    edited February 2006
    Very nice work!
    "God grooves with tubes."
  • brettw22
    brettw22 Posts: 7,623
    edited March 2006
    Looks very good......
    My only concern would be if you should have any sort of potential short inside, the last thing you'd want around sparks is wood........but definitely, looks good.
  • jcaut
    jcaut Posts: 1,849
    edited March 2006
    Yeah, I thought about that... My only real concern would be with the switch, which is sitting right on the MDF. The other connections and wiring inside is really solid/overdone, and all the wiring I did inside to extend the case is soldered, taped, and heat-shrinked.
    I might look into some sort of metal shielding to go around the switch, just in case.
    Thanks for the comments.
    Jason
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2006
    Jason - It looks real cool. If a fire is going to happen, it will happen regardless of wood being present....no worries.
