UPDATE - LSI Series and AMP chosen
Well, to start off, I can say I was a real noob when it came to theaters. I can proudly say with the help of all you guys that are so passionate about this stuff, I think I got a really really good system. I started off with the complete LSi lineup, with LSi15's, LSiC, and 4 LSiFx for surrounds in my 7.1 setup. When I went to seriously discuss amplification for those monsters I came to the conclusion that anything available in most retail outlets just wouldn't cut the cheese. I hummed and hawed over it for weeks and finally chose an Outlaw 990 w/ an Outlaw 7700 Amp. I can certainly tell you that this setup is very rock solid. I was a noob as mentioned but I don't think I have heard anything sound so good. Everyone I have had over just drools when the evaluate my setup. The install of the gear is pretty simple and the menu of the 990 is straightforward. Thanks again to all of you who helped me earlier in my selection...or better yet, your discouragement of my previous choices.
Cheers,
Cammrit
Cheers,
Cammrit
Post edited by cammrit on
Nothin' beats doin' it right the first time............:D
Congrats!!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yup.. you did it right the first time. You bypassed all the mistakes I made. Good luck with your new and awesome system!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Congratulations, enjoy!!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Cool.
What kind of subwoofer are you using?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Good Job.
Sit back relax and get your listen on.Proud SOPA Member since 2005! -
THAT will get the job done. have fun!
Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Early B, the sub I chose was a Polk PSW505. I haven't had too much time to tweek this but it sounds pretty good. I have read a lot about people adjusting the crossover and changing the connection method. Right now I just have my factory crossover setting on my Outlaw 990 and have the sub hooked up via the Line in (Filtered) input. I beleive the sub, even more so than the other speakers really depends on room acoustics and the bass management of your construction and finishing details of the room. My room is about 18' x 13.5', with concrete perimeters on 2 walls and the floor, so when I built the room, I wired it for an additional sub on the opposite side of the room to try to compensate for the deadening concrete if need be. My feeling was that instead of going overboard on one sub, I would rather have 2 smaller ones. Not that the 505 is small by any standard. I do have a second kick **** Velodyne that I was given from my inlaws. One catch is I think I need to rebuild/replace some of the components in it because it kind of pops and hums when it gets hooked up. I plan to fix it up and then compare it to the Polk...I'll let you know once it's done. Unfortunately I am going to take the advise of all the Polksters and just sit back and watch some hockey on the big screen for a few weeks (Yup, I'm from Canada)
Cheers,
cammrit -
Awesome system...all LSi line complete. :cool: EnjoyMy current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
