FXi3's Side Mount Question
reubenray
reubenray Posts: 91
edited February 2006 in Speakers
Being I cannot install my new speakers behind me I will install them on the side of the listening area. Do I want them even with me or in front of me? Also I assume I would set them on Dipole. Is this correct?
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
  • Drummerboy
    Drummerboy Posts: 15
    even, 90 degrees directly at your sides. I got this recommendation from THX and i use the same ones, which are great sounding speakers!
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Slightly behind if you can, to keep front info from mixing with the sides, and dipole is preferred.
