I swithced out my stock jumpers and..
phipiper10
phipiper10 Posts: 961
It would be easy to say there is more detail? I'm really not sure but I feel cool just for having done it.
I did in fact hear something for the first time that I hadn't heard when I listened to track 2 of Sarah McLachlans Solace. About 42 in there is a slight pop (her lips maybe- she isn't just taking a breath or maybe it's something else I don't believe it was intended to be there.) I had listened to this track about 10 times this weekend after upgrading my ICs.
Anyway my question is why would I bother with heat shrink? I've seen many people referring to having done this for their homemade jumpers. Seems stripping some decently insulated speaker wire to but plastic over instead would be odd but maybe I'm missing something.
I'm open to other suggestions on how to best do this. Of course going to say a 10awg is one option and the second would be to shorten what I have down to just the distance between the posts. So I'm aware but not sure how much benefit there might be???
Also note that one banana plug (left -zoom in) won't go in all the way. This is the same on the other main speaker. Just one won't go in completely. I've pushed pretty hard but don't want to mess up the posts.
Other thoughts suggestions, experiences? I'm open to suggestions and of course I'm particularly curious about using the heatshrink. I will say I believe definitevely that the Diamondback interconnects were an upgrade over the Copperheads I had.
Rich
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
  • phipiper10
    edited February 2006
    Correction it was actually "Wait" from Fumblig Toward Ectasy where I hear the little "pop" in case anyone else was actually going to try to hear it.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    You could always use premium quality stuff instead of the MC.
    These Kimbers are only $1800.................
    F1nut Posts: 51,794
    You don't need heatshrink and what you've done is fine. No need to shorten the jumpers or remove the spades. Relax and enjoy.
  • steveinaz
    steveinaz Posts: 19,545
    Try rotating the banana about 1/16" and reseating it. I have a terminal on my parasound that I have to this with because of a slight burr in the terminal channel.
  • BobMcG
    BobMcG Posts: 1,585
    Plus 1.
    On spades: Get rid of the spades? Yeah. I'll just chop them off my 25 hundred dollar Dragons and they'll be so much better.:rolleyes: Quality spade connections will be the least of your worrys.
    Plus 1 here too.
    On Polk's posts: As much I like Polk I do have to say that their posts leave a bit to be desired. They're much better than they used to be but could still be improved upon. You could do this yourself quite easily though.
  • phipiper10
    Regarding where to place plugs. Of course I can try it at home but is there any reason for better or worse to plug into the top vs. bottom binding posts and vice versa?
    F1nut Posts: 51,794
    It makes no difference in your case.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2006
    +1.
    Spade connections are the preferred connector whenever you have the ability to use a high quality one.
    You did a nice job.
    RT1
