Can I use the plate amp in my PSW404 to..
Mike682
power an SVS CS sub?
I was checking them out and was wondering if it would work (I'm not concerned about power, but rather the actual connections, placement, etc. of the Polk plate amp). I could save some cash if I just swapped the Polk amp to the SVS..
Thanks in advance.
Mike
Thanks in advance.
Mike
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Mains: polk R30
Center: polk CSi3
Post edited by Mike682 on
Maybe... frst off check the impedences- if the SVS driver is four ohm and the Polk is 8, then you're outta luck- the polk amp will melt if you try to drive the SVS loud (which is what you want if you've got a SVS).
The only other possible problem is if the polk amp has some active EQ going on- sometimes they'll boost the frequencies as the driver starts to roll off to get a little lower extension. I'd drop Ken a line & see what he says.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
UNC,
Excellent points regarding impedance and possible EQ issues. I was wondering if Polks were 4ohm. I will wait to see what Ken says. Thanks a ton for the response.
MikeReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
DVD: Panasonic DVD-S29 -
We use active EQ in the plate amp, so driving another woofer is not recommended.-Eric
-Polk Audio -
Eric Wong wrote:We use active EQ in the plate amp, so driving another woofer is not recommended.
Eric,
Thanks for info.
Mains: polk R30
Center: polk CSi3
