New Setup Questions??
reubenray
reubenray Posts: 91
edited February 2006 in Speakers
I got my new Onkyo A/V receiver and have set it up, but have some questions concerning the setup of the rest of my equipment. You can see in my signature what I still have coming. Right now the receiver is hooked up to my old Sony speakers and sub.
1) Being I will be using a 5.1 system now where do I wire my FXi3 speakers. Will it be the surround back or just the surround ? I just watched a movie and never did hear anything from my surround speakers.
2) If anyone else has a Onkyo receiver what is the best audio setting for the best sounding DD output. It seems like the dialog is coming out of all of the front speakers instead of just the center speaker on the DD setting.
3) How would it work if I kept my 2 Sony surround speakers to make up a 7.1 system?
Thanks,
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
  • TheReaper
    TheReaper Posts: 636
    1) fxi3 as the surround L/R speakers
    2) I use PLIIx Movie. You should also run the auto-setup with the microphone to get a start on balancing the speaker outputs.
    3) depends how they sound, give it a try and see.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • reubenray
    reubenray Posts: 91
    I did check and I had the surrounds wired as the surrounds back and the book says to wire them as just the surrounds for 5.1. When I get the FXi3's I will redo them as backs and see how they work.
    I did do the auto-setup with the microphone.
    Now here is another question. I set everything up as THX. Is this correct for the crossover?
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • aaharvel
    aaharvel Posts: 4,489
    Reuben, with a 5.1 setup, place the fxi3's to the sides of the room in dipole mode (i use bipole mode for 7.1).
    Make sure the speakers are NOT hooked up to the rear surround speaker terminals on your receive.
    You can try the Sony's as rear surrounds if you want for the sake of 7.1 experimentation- but I wouldn't. Timbre matching will be off- and a poorly setup 7.1 system sounds inferior to a good 5.1.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
