System Tuning
quasi
I'm using Polk Rt15i's for main and rear surround and a CSi30 center all hooked to a Yamaha RX-V420 amp and a Yamaha YST-SW205 sub. Sounds pretty good, but I'm not getting a whole lot of sound out of the rears. Can anyone suggest what to change. I can't find where to up the volume for the rears on the V420. I would have thought using 4 of the same speaker would make for a fairly even sound........
Post edited by quasi on
Hi and welcome to the forum. See page 38 of your owner's manual to adjust your speaker levels:
http://www.yamaha.com/menuitems/manuals/yec/RX-V420.pdf
Ideally, you should use the Avia or Sound and Vision DVD (or equal) and a sound level meter to calibrate your system. Some people like to run their rears a little "hot" at +3 db from the calibration. -
this was the same topic as my first post .. spl meter and the avia test disc .. after i did this it completely changed what i heard.Sharp LC-46D82U
Yamaha HTR-6190b AVR
Pioneer DV-578A
Sony PS3
Sony CDP-CE375
Sharp VC-H953
Belkin PureAV Home Theatre Power Console PF60
polkaudio R30-Mains
polkaudio R30-Rears
polkaudio Csi3-Center
Paradigm PS 1200
Harmony 880 Universal Remote Control -
Avia test disc. You hear "other things".
My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
Thanks guys..... so where do I get this test disc from ?
Thanks again ! - if anyone has a used copy going cheap I'd like to hear from you - specially if you're in Australia
Never mind - managed to borrow a copy locally - it's all configured and sounding sweet now !
Thanks again guys
