need help fast!
kylescooter
hey everyone. need help fast! does this set up sound ok?(found all this on an auction site). polk rm series2 4sattelite speakers(need another if someone has one) cs100 center speaker,and a pair of r 30 front mains?(or would a pair of infinity rs4's be better mains(and should I mix brands?) I have a 6.1 onkyo home theater in a box.will this speaker set up be alot better than my speakers that came with my package or do you reccomend another package that will beat my onkyo's on the cheap? I have to keep my reciever for now.(ht-r510) thanks all!!! ..... kyle
Post edited by kylescooter on
What type of budget are you looking? If you are not in a hurry, watch www.outpost.com for Polk's R30's, R15's and a CSi25. The 30's on sale can be found for $125-$150 a pair, the 15's will usually run you around $50 a pair, while the CSi25 can be found for between $75-$100.Tschüss
Zach -
The Polk satellite system should definitely beat the Onkyo HTiB, but neither are anything to write home about, imo. It really depends on what you're looking for and what your budget is. okiepolkie's suggestion is a good one. If you could piece that system together for about $250-$300, it'd be much better.
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
thanks for the quick replies.I can get all the speakers I mentioned for about 250 or less.I was just wondering if these were any better than my onkyo's or if I should just wait and try to piece together some better speakers. my budget is about 300-350. thanks all... kyle I hate to ask, but would a cheap flaunce 6.1 set be worth it? and are the the same quality as the lower end polks?
I can't comment on the Flaunce setup, but like I said with the Polk, they should be better than the Onkyo HTiB. However, one doesn't typically move up from a HTiB to another HTiB. None of them are going to be *good*. The next real step up would be to piece together a system with bookshelves/towers for mains, and bookshelves for rears and center. That would be a vast improvement, and the system that okiepolkie 'pieced together' is not much more than this Polk satellite system.
However, you don't have to go with the R30/R15/CSi25. If you pass on the satellite system and thus are no longer governed by time restraints, I would watch the Flea Market. There are usually good deals to be had on speakers, and if you're patient, you just might be able to piece together a real nice system for not too much money.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
SURELY..this set of speakers are FAR better than your HTIB system. Is other level of audio. No comparisson.
My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
thanks all for the replies.I just thought these were a good deal and didn't want to miss them.(4 sattelites for 150.00)If they are about the same as htib speakers,then I definately wait and try to find some better deals on some better speakers. what would you all reccomend for a 6.1 for < 500-600 total?maybe a little more.I will keep my sub for now and will add another one later.( you can include one for me if you want,but seperate cost.) thanks for all your GREAT help!!......kyle
Since you are not opposed to going used, you can put together quite a system for that price range. Look at some the Polk RT series speakers on ebay. It helps if they are of the same model year, but some of them are reasonably interchangable.
Whenever you need help, just let us know. Where are you located? Some of us might be able to let you listen to the surround systems we have put together. I'll look at some of the options tomorrow when I actually have a little time.
BTW, welcome to the forum.
edit: sorry for ending my post abruptly earlier, I had to leave in a hurry.Tschüss
Zach -
I live in wichita falls,tx.and bestb and circutc are pains in the butts about letting you listen to and try stuff unless you have a gold card in your hands.as are the home theater stores here. the only advice I have is from you all and I appreciate all your help. I will look on ebay for some more deals. so what would be the ideal center,mains(tower-not bookshelves)and 3 surrounds on a budget that will be mid level quality to piece together? please spell it out for me,as I know nothing about models and series.a full grouping if you will(6.1). I'm sure alot of you had your first speaker set and have upgraded when you got the mega bucks.tell me what you started with and how it sounded and what reciever you used that has at least 100w per channel.( I just learned that my onkyo 600w is only really 45-50 watts per channel!....what a rip! and I will have to keep it for awhile. thanks all!...........kyle
Hey Kyle, welcome to ClubPolk.........I think the R series towers would do you good with your Onkyo receiver. I like Zach's lineup of the R30s (tower), R15 for surrounds/rears and CSi25 center. This could easily be done for your under 600 budget with new speakers bought right. The RT/RTi lineup from a couple years back would be a step up from those and could be pieced together for something close to your budget.
DennisHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Put me in the camp of those who think the rm satellites are actually pretty darn good for HT.
Kyle,
Good to see you made it from the other forum. This forum will get you lined up with what you want.
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer -
If you are set on floorstanding speakers for the fronts, then it will make it a little more difficult to stay on budget with the RT series, although it is not impossible.
Here are a couple of systems you might look for as you watch the used market:
system 1:
fronts: RT400's -rare, but can be found for $150
center: CS225 or CS250 - $75-$100
rear: RT3's, RT5's -$75-$100 per pair
System 2:
fronts: RT600's or RT800's(regular or i versions $150 and $300 respectively
center: CS245 or CS400(reguar or i $100 and $200 respectively
rear: RT15's, RT25's, RT35's, FXi300 regular or i $75, $100, $125, $175 respectively
System 3:
fronts: RTi70's - $300
center: CSi30 or CSi40 $125 and $200 respectively(CSi40 available on the forum)
rear: RTi28, RTi38, FXi30 $140, $150-175, $175-$200
Again, these are only sample systems. You can piece them together one at a time to stay under your budget. Since you already have speakers, it doesn't make a huge difference where you start.Tschüss
Zach -
thanks all! you have been ALOT of help and I really appreciate ALL your repilies and help! it is so hard to decide on speakers and a receiver when upgrading from a htib towards a real home theater.I am so amazed at all the 100's of choices out there and it makes it very difficult to comprehend and make a choice.polk,klipsch,boston, bose,yamaha,bic,flaunce, and on and on! my head is spinning! you guys ROCK!!! thanks!!!! .............kyle
