YAMAHA RX-V750 vs. RX-V2500?
montreal
montreal Posts: 10
edited February 2006 in Electronics
Help guys. Which one is better and why? Is the 2500 worth the extra $200.
Front: Monitor 60 polk
Center: CS1 polk
Surrounds: R15 polk
Post edited by montreal on
  • Willow
    Willow Posts: 11,256
    MTL, how much are the charging you for either or ?
    http://audioshop.on.ca/yamahareceivers.htm#rxv1500
  • montreal
    montreal Posts: 10
  • Willow
    get the 2500 and don't look back. You won't regret it. If you buy the 757, later you might think ...I should of bought the 2500 when I had the chance...avoid that...unless $$ is a tight.
  • montreal
    montreal Posts: 10
    Thank you Willow!!
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    You can't compare this receivers....is other category. The 2500 series has THX surround programs, on screen with GUI, more connections, more power, more DSP programs, every made of aluminium (no plastics !!!) and a lot of things.
    The price is more higher...but, definitive far best.
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • Willow
    montreal wrote:
    Thank you Willow!!
    No prob....where in MTL are you shopping? I'm only 1.5 hrs away, this might warrant a drive down there.
  • WilliamM2
    WilliamM2 Posts: 4,808
    Seby,
    I think ALL the RXV's are aluminum, the HTR series are plastic.
    My RX-V1500 has the THX modes, I never use them, mostly just DTS because it sounds better.
  • *Seby*-Polk-
    WilliamM2 wrote:
    Seby,
    Yes??? mmm...i should listen THX modes again...
    Anyway, when you listen 2 ch music...what mode of DTS or Dolby uses ???
  • WilliamM2
    When I listen in two channel, I usually bypass the reciever all together, one of my CD players is connected directly to my power amp.
    If I do listen to music in 5.1, I prefer DTS Neo 6. But I prefer almost all of my music CD's in 2 channel. Some CD's I listen in "straight" mode, which is the front speakers and sub only, no surround processing.
  • *Seby*-Polk-
    Ok. I will check this DTS Neo 6 mode. ;) You feel a difference of sound between 2 channel direct stereo to pure direct ????
