RTi6 speaker mounts
Giuseppe
Giuseppe Posts: 42
edited February 2006 in Speakers
Hey guys
I have a question about mounting my RTi6's. I have done a search and read that some of you guys are using the B-Tech BT77 wallmounts. After looking them up I noticed that these wallmounts accomodate speakers that are a maximum 13" deep. The RTi6's are over 14". Are there any other wallmounts out there that can handle these speakers, or have you guys used these mounts anyways and found that they did fine?
Harman Kardon AVR 7300
Monster MK II Power Center
Logitech Harmony 890
HSU VTF-3 MK2 Sub
Polk Audio RTi10
Polk Audio RTi6
Polk Audio FXi3
Polk Audio CSi5
Post edited by Giuseppe on
  • Giuseppe
    Giuseppe Posts: 42
    Someone on this forum has mounted these things on their wall right????
    Anyone??
    HSU VTF-3 MK2 Sub
    Polk Audio RTi10
    Polk Audio RTi6
    Polk Audio FXi3
    Polk Audio CSi5
  • Giuseppe
    Giuseppe Posts: 42
    hello?:D :):p;):o:(:confused:
    HSU VTF-3 MK2 Sub
    Polk Audio RTi10
    Polk Audio RTi6
    Polk Audio FXi3
    Polk Audio CSi5
  • louhamilton
    louhamilton Posts: 209
    I think it depends on how far you want to tilt the speakers.
    As a precaution, I have black zip ties fastened to the hole in the base to the keyhole on the Power Port. Keep in mind that I have my RTi4's inverted (upside down) so this makes for a very short zip tie run.
    The other option is to use the screws included with the B-Tech BT77 mount and screw them into the speaker cabinet. There are hole in the bottom mount, so you would only have holes in the bottom of the speaker rather than on the sides.
    Just some thoughts.
    -Lou
  • Giuseppe
    Giuseppe Posts: 42
    thanks for the ideas. I will consider them.
    HSU VTF-3 MK2 Sub
    Polk Audio RTi10
    Polk Audio RTi6
    Polk Audio FXi3
    Polk Audio CSi5
