First Polk setup
Drummerboy
Here it is : RTI8's for fronts, RM6600 home theater package for center, surround and surround back, and a PSW505. All driven by a pioneer VSX-1015TX. Hows that sound? thinking of upgrading the RM6600 speakers with a csi3 center and 4 rti4's. but for now this will do. opinions?
Post edited by Drummerboy on
good choice but your centre....has to be changed you are not getting it all. aslo your rears need the upgrade as well.
But how does it soudn to you? -
I would place a much bigger sence of urgency upon upgrading your center. go CSi5, so your not limited down the road. I a big proponent of going big on the center. would rather turn a big center down than small center louder.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
I Don't like Pioneer amps (except Elite line). I recommed you models of Denon or Yamaha with your speakers. Try it.
ByeMy current new system (step by step )
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
