delicious nanners
edited February 2006 in Speakers
I just bought some cheap Acoustic Research banana plugs (AP 307's) to fit on some 10 gauge wire, so you may want to file this thread under the "what was he smokin' and/or tokin' category." :p Either way, anyone familiar with these, and better yet, do I stand a snowball's chance at making them work?
If not, I'll just use 'em for something else...
Post edited by zombie boy 2000 on
Welcome!
    Just pull down (or off) the red and black insulators and you'll see set screws. Unscrew them, place the bare wire inside and tighten the set screw then replace the insulator. Is that what you were asking? :confused:
    well yes/no...
    looks like you can feed the wire inside, but further up, there looks to be a smaller hole about 1/4" deep -- i'm assuming this is were the wire needs to connect
    i can put the 10 gauge easily into the first hole, but it's not all going through the second if you catch my drift
    so should the screw tighten on the bare wire? it was my understanding that the screw was there to hold the "jacketed portion" of the wire in place, with the bare portion inserted into the aforementioned 1/4" hole?
    and if the screw just tightens on the bare wire, will there be any problems with so much of the wire "exposed" or is this what the insulation is for?
    this is really no big deal, but i appreciate your response dragon :)
    The set screw screws down on the bare wire. Just twist the wire reall good and you can fold it over and double it up for a tighter fit. You can cut the wire so that no bare wire is visible but the insulators should cover it. I usually leave the bare wire long enough to fit all the way up and then tighten, but it doesn't necessarily have to go all the way up. The entire connector is part of the conductor.
    thanks dragon.. makes all the sense in the world
    i guess that "hole" farther up in the plug had me second guessing the "hole thing" (groan....)
    appreciate your time :)
    You're very welcome my fine young ghoul. yeah, that hole is probably where it narrows out and the nanner tip starts.
Welcome!
Welcome!
