RTi10 bass
edited February 2006 in Speakers
Hey guys, I bought my RTi10's about 5 days ago ans connected them to my HK 7300. I remember a bunch of you guys saying that is has really good bass. I set the crossover point on the RTi10's at 40Hz, but I still don't get that much bass. They are about a foot and a half away from the rear wall. My friend has an 8 inch quest sub with a 110wat amp that has alot more bass then the 7.5 speakers on the RTi10's. Is this normal? or did I not connect/calibrate something correctly? THanks
Harman Kardon AVR 7300
Monster MK II Power Center
Logitech Harmony 890
HSU VTF-3 MK2 Sub
Polk Audio RTi10
Polk Audio RTi6
Polk Audio FXi3
Polk Audio CSi5
Post edited by Giuseppe on
Welcome!
    Check to make sure you connected them correctly. If you've reversed the polarity on them (gone from positive on the amp to negative terminal on back) it'll mess things up some. Can't remember if they are, but if they have two sets of binding posts per speaker and you're using a single run of wire or a single amp make sure the gold jumpers are in place.
    prob. normal. They won't put out the bass of even a decent sub. Not designed for that- their woofs are passive.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    are they set to large?
    RTi10's are not meant to have tons of bass? If you want bass, you definetly need a good subwoofer. IMO, I'd rather have the RTi8's and a good sub anyday over the RTi10's.
    Mike
    Yeah I set them to large. What are gold jumpers? maybe that is a really stupid question lol.
    HSU VTF-3 MK2 Sub
    Polk Audio RTi10
    Polk Audio RTi6
    Polk Audio FXi3
    Polk Audio CSi5
    Personally, I like the 10's a lot better than the 8's, sub or no sub. However, I would never run the 10's alone w/o a sub for music. They just don't go low enough. They do have a great deal of bass for the size, though. With good amplification, they perform well. If you were in a studio apartment, they'd be plenty. But in a house, you need a sub man.
    That said, there are a lot of other speakers out there that get as much if not more bass from drivers of similar size. The Vienna Acoustic Beethoven Baby Grands get more bass from two 6" drivers and one port than Polk's 2 7" drivers and their dual sided "power port." However, there's also a difference of about $2500 between them as well, so it had better result in something.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    Thanks, I actually purchased a HSU VFT-3 MK2 today. It is amazing! This thing goes so low with no distortion of anything. It really brought my HT system alive.
    HSU VTF-3 MK2 Sub
    Polk Audio RTi10
    Polk Audio RTi6
    Polk Audio FXi3
    Polk Audio CSi5
    Gold jumpers are the thin little metal plate thingies that connect the top binding posts to the lower binding posts. They should be a shiny brassy / gold colour. Some replace them with wire but it doesn't really matter as long as you have something there.
Welcome!
Welcome!
