need help with setting crossover
hi all,
what is a good crossover setting for my system?
i have h/k 7300, front rti10, center csi5, surround rt25i and no sub.
thanks a lot.
thanks a lot.
Sony 60" XBR2
PIONEER SC 05
Samsung BD-UP 5000
7.1 SETUP
Infinity P-FR with 12" build in sub
Infinity P-CC
4 Infinity P QPS
Kef sub 4000
pure av PF60
3 cobalt speaker cables
PIONEER SC 05
Samsung BD-UP 5000
7.1 SETUP
Infinity P-CC
4 Infinity P QPS
Kef sub 4000
pure av PF60
Post edited by thuchien on
Rti10- Large
Csi5- Small (60hz)
Rt25i- Small (80hz)
when you get a sub set the rti10's to 40. -
thanks
do i need to set crossover for rti10??Sony 60" XBR2
PIONEER SC 05
Samsung BD-UP 5000
7.1 SETUP
Infinity P-CC
4 Infinity P QPS
Kef sub 4000
pure av PF60
3 cobalt speaker cables -
No, the lower frequencies from the center and surrounds are going to your fronts so your fronts are pretty much doing all frequencies.
does that make senseAVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
so it means that i can leave as receiver defaut setting ( front 100 )and only adjust for center and surround?Sony 60" XBR2
PIONEER SC 05
Samsung BD-UP 5000
7.1 SETUP
Infinity P-CC
4 Infinity P QPS
Kef sub 4000
pure av PF60
default means that the crossover is at 100hz straight from the factory. bad, bad, bad.
Large= no crossover. Set it like most would do back in the pro-logic days.
Front- Large
Center-Small
Surround-Small
if your crossover is adjustable, then do what i said earlier. Those rti10's will sound better with the center and surround bass being directed to them. -
FWIW with my 8s I have everything set at 80.
