HK Question
donedroolin
Does anyone know what the watts the 7300 puts out at 4 ohms I cant find it. Thanks for help.
TV- 52 inch LCD SONY BRAVIA XBR6
TV- 42 inch PLASMA HITACHI ULTRA VISION
AMP- PARASOUND HALO A-51
CONTROLLER- PARASOUND HALO C-2
FRONT SPEAKERS- LSi15's and LSiC
REAR SPEAKERS- LSi7's
SUBWOOFER- VELODYNE DD15
BLU RAY- LG SUPER BLU BH200
BLU RAY- SONY BDPS350
GAME SYSTEM- NINTENDO Wii
MONSTER POWER CONDITIONER
WIRES- AUDIO QUEST and MONSTER
Post edited by donedroolin on
4ohm figures for Harman Kardon receivers don't exist b/c they're not designed to support 4ohm speakers.
However, that receiver would do a much better job than most out there. -
Hey Thanks , B&K are rated for 4 ohms right the 507 S2 will push 185 watts into 4 ohms does anyone know if this is accurate.TV- 52 inch LCD SONY BRAVIA XBR6
WIRES- AUDIO QUEST and MONSTER -
Funny, my HK supports 4 ohm loads quite easlily."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
They do, just aren't rated.ND13 wrote:Funny, my HK supports 4 ohm loads quite easlily. -
They are for stereo operation, not too sure about mc, though."SOME PEOPLE CALL ME MAURICE,
They won't post a rating for 4 Ohm loads because they don't want people running (7) 4Ohm speakers, frying the output devices and sending them back for warranty work. It will drive 4 Ohm quite well in Stereo when the Amp config is in 2ch. It will drive them passably well in a 5.1 setup, but I wouldn't use (5) 4Ohm speakers. At most I would drive 3. I am currently driving 2 with the HK630. I will be adding a third -LSiC, and I'll be crossing my fingers.
I had read a review from a reputable mag that the HK6xx rated at 75 watts @8Ohm would actually drive 126 watts at bandwidth at 1%THD and 135 at audible clipping. I don't recall the measuring parameters, but owning it, I tend to think that it's closer to 100 than 75, and driving a 4 Ohm it should be in the 150 range. Sounds great in 2ch, but I will be using those preamp outs when I can afford a complement of Parasounds or higher.-Ignorance is strength -
