Speaker Cabinet care
Drumingman
Drumingman Posts: 348
edited February 2006 in Speakers
For those of you that have real wood cabinets, what do you use on them to maintain them when cleaning?
Post edited by Drumingman on
  • wirebill
    wirebill Posts: 63
    Drumingman,
    Any good furniture polish will do. I have been using "Old English" lately.
    Bill
    VR3 Posts: 28,779
    When you say "Real Wood" do you mean veneer?
    Water.
  • Drumingman
    Yeah, veneer, real wood.
    I want to keep them looking good and not let the wood dry out while at the same time not getting a "dull wax build up".
    No water for me on the cherry veneer.
    VR3 Posts: 28,779
    Well dont use pledge.
    I still say water is your best bet.
    We've had this discussion so many times before, its not even funny.
  • MattN03
    MattN03 Posts: 558
    What does Polk recommend?
  • WilliamM2
    WilliamM2 Posts: 4,781
    I would agree with Sid, NEVER use Pledge, Old English, etc, on real wood veneer.
    But I wouldn't use water either, as that will just dry the wood out more.
    The instructions that came with my SDA's say to use a light coating of lemon oil to keep the wood from drying out. I've never bothered on my 17 year old SDA's, I just dust them occasionally, vacuum off the grills, and they still look new.
    If they really need cleaning, you may want to try something like Murphy's oil soap. We use it on the real wood panels of our summer cottage with great results, but I have never used it on speakers.
  • wirebill
    wirebill Posts: 63
    I have a custom made, solid cherry wood audio cabinet and I will never use water to clean it. I use "Old English" a couple of times a year to keep it from drying out. I use a vacuum with a very soft brush and dust it off with an old soft tee shirt every week and polish it a couple of times a year. I do the same thing with my Ohm speakers and they still look great after 27 years.
    Bill
  • Joey_V
    Joey_V Posts: 8,586
    Just dont use water... it will destroy the wood veneer and make it peel. I did this with one of my speakers before, good thing there was still some of the 30day return/exchange period left over.
  • dorokusai
    dorokusai Posts: 25,577
    I use the blood leftover from my animal sacrifices to the audio Gods, while dancing around covered in excrement.
  • Willow
    Willow Posts: 11,058
    Looks like I'm not the only one ! and you know something I think I'm starting to see a difference ! ;)
    But as Sid mentioned, I use a damp cloth followed right after by a dry one. We are not talk ing about putting a hose to it, but a damp paper towel or cloth. Once in a while. Besides dust there shouldn't be much dirt except you left over greasy KFC finger prints.
    I use a swiffer duster 2x a week. Clean as can be.
    F1nut Posts: 50,746
    The Wood Jedi here.....
    You want the wood DRY. You do not want moisture or oil in the wood. That's one of the reasons clear coat finishes are used, to keep that stuff out of the wood. All finishes have a life span and none of the cleaners/polishes will extend that life span.
    The best way to dust/clean your speakers/furniture is with a well rung out (water) cotton cloth followed by wiping with a dry cotton cloth. Endust is ok, but always spray it on the cloth, never on the furniture. Another ok product is Guardsman Polish, it's water based, no build up.
    Old English, Lemon oil (really just mineral oil with a lemon scent), Pledge (silicone...nasty stuff), etc. are a waste of money and Murphy's oil soap is veggie oil based, think rancid, nasty build up.
    VR3 Posts: 28,779
    Yep...
    WATER rules.
    My speakers have 6 coats of clear on em though, I could blow on mine and itll all come off. Slick stuff buddy.
  • Joey_V
    Joey_V Posts: 8,586
    I guess what I meant was not too much water.... I think I almost drenched mine.
  • Drumingman
    How do you know 6, did you put on any extra?
    Hey Mr. Polk, You ought to let your customers know!
    Mr. Polk is probally a nice guy.
    It was Mr. Bose who put the Cuss in customers.
  • Drumingman
    Oh! Clearcoat! I got it, I can use Maguires!
    VR3 Posts: 28,779
    I *built* my speakers...
    I put 6 gloss poly clear coats on em...
