dual subs with different driver sizes
krabby5
krabby5 Posts: 923
I just bought a SVS 25-31 pci to replace a Velodyne CHT-8
Since I still have the Velo, can I pair them together or would that be dumb?
Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
Post edited by krabby5 on
  • Frank Z
    Frank Z Posts: 5,860
    edited February 2006
    Overkill actually. You probably wouldn't like the results too much. I'd be concerned about cancellation creating a huge null in the lower end.
  • krabby5
    krabby5 Posts: 923
    to Ebay they go!!
  • dudeinaroom
    dudeinaroom Posts: 3,609
    your not gonna offer it here?
    VR3 Posts: 29,434
    When you mix two subs, and one is the lesser (much lesser) of the two, it will be cutting out at a lower volume AND it wont be hitting as much.
    So you would get reinforcement above the lesser subs cut off point, but it wouldnt be much especially since the SVS could make the Velo hop out of the room.
    Congrats on the SV.
    VR3 Posts: 29,434
    Did you get the 22hz tune?
  • krabby5
    krabby5 Posts: 923
    You know, I mentioned in he comments that I would like it tuned to 22 hz..
    How can I tell if it is?
    VR3 Posts: 29,434
    It will have a 15" port (I think) instead of a 13" port)...
    If I remember correctly.
  • krabby5
    krabby5 Posts: 923
    I would..but I don't I'm afraid of shipping the 44 lb thing
  • goingganzo
    goingganzo Posts: 2,793
    i seccond selling the velo there is a small differance between a this and last moddle year of the same driver but 2 way different subs no stay with one. but the velo might be better for music if you want to swith them off one for music and one for ht
  • krabby5
    krabby5 Posts: 923
    hmm..Ill check it out when I get home
  • krabby5
    krabby5 Posts: 923
    They just confirmed in an email that I did, indeed, get the 22 hz tune...
    cool!
    They said unless I take the sub apart and measure the port, it doesn't look any different...
