Best Amp For HK AVR630 and RTi10s
cbl117
hey guys
I just purchased a pair of RTi10s for music listening and I'm thinking about getting an external Amp and using the HK AVR630 as a pre-amp. Whats the best amp to throw into this equation? I was thinking 200 wpc would be enough...am I correct in thinking that? I really like the sound of polks and HK, so keeping the sound is a must. I just want to pump more wattage into the RTi10s to get a cleaner, louder, and tighter sound.
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
Post edited by cbl117 on
CBL,
I really enjoy my Outlaw amp which is a 7 channel that pushes my RTi12's. Outlaw has some real nice mono-amps, M2200, which will give you 200watts per channel. Check out their link:
http://www.outlawaudio.com/products/index.htmlHolydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Hi Cbl! Yes, I would say 200 wpc is the minimum you should go for. Outlaw is good, as is Parasound, Rotel & several others. Especially if you get them used.
Let us know what you end up getting & what you think of the difference in sound!cbl117 wrote:hey guys
I just purchased a pair of RTi10s for music listening and I'm thinking about getting an external Amp and using the HK AVR630 as a pre-amp. Whats the best amp to throw into this equation? I was thinking 200 wpc would be enough...am I correct in thinking that? I really like the sound of polks and HK, so keeping the sound is a must. I just want to pump more wattage into the RTi10s to get a cleaner, louder, and tighter sound.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Hey guys thanks for the posts to get me started in my search.
I've looked at outlaw and parasound so far. I'm interested in the parasound model 275. Its 2 channel 75wpc, but I'd buy two amps and run each bridged for 200 wpc. My only concern (besides money... ) is the peak current ratings. My AVR630 has a peak current rating of 50 amps per channel, but the parasound only has 30 amps per channel. Is that something I should be concerned about? Also will this amp color sound in any way?2 Channel
Vandersteen 3a Sigs
Hovland HP-100
Rotel RCD-1072
PS Audio UPC-200HB
