Centre ch. decisions.
Willow
Willow Posts: 11,058
edited February 2006 in Speakers
I would like to know how many people have used a centre then opted to go phatom and what the results where.
Is there anyone out there using a 4.1 system fronts and rears only ? how do you find you set up for HT.
We are having a very hard time find a tv stand which will accomodate all my gear and a centre ch on the stand.
I have :
xbox
marantz dvd
Oppo on the way
HK 335
HD cable box
I can't seem to fit all of this on a stand without it looking stuffed. So I am thinking of ditching the centre Ch. would this be a big error or should I just keep looking ?
Post edited by Willow on
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    i think the center channel is important to listen dialogues and effects like explotions or something.
    Maybe, is most important got fronts and rears...but...in the future you must bought a central. CS2 ??? i listen and it's great. (with low bucks..obviously)
    Bye Willow !!!! (this time...i don't insulting your systems !! haha ;) )
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • aaharvel
    aaharvel Posts: 4,489
    4.0/1/whatever works great for music and SACD.
    for movies, try it. If you don't like it, buy a center. :)
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Willow
    I already have my 8s,3 and 4s. I was just looking for opinions on running without the 3.I don't do SACD and reg music is in 2ch.
  • SKsolutions
    SKsolutions Posts: 1,820
    Out of necessity I am currently running a 4.0 sys with Lsi9 mains and rears. I am still trying to figure out the positioning of the center because the area behind the plasma is glass (window). So, I'm running a phantom front stage and it sounds centered enough that I don't really spend much time figuring out how I'll mount a center. The solution here would be to toe in liberally and limit the spacing between the mains. This gives you a smaller soundstage for 2ch, but you can find some compromise. My 9's are 18" left and right of the plasma for a total of about 7 ft. This may not be optimal for imaging instuments, but it's quite functional in HT. The test tone pan sweeps sound like a 5.1 when it goes from LF to LF and RF equally. It's workable, but I will cable mount/hang a center at some point.
    -Ignorance is strength -
